I'll try it with the other suggestions sometime soon. :up:
Thanks!
You could easily fit another 2.120 radiator up there, it's about 8,5cm from the top to the motherboard if you use the original hard drive cage and 5,25" slots.
Thanks, yeah I did.
You could probably buy another stock cooler from someone who's doing LC or something, and paint i instead. :)
No I peeled it off with a needle before painting the housing, it was thick separate letters with some glue on the back. ;)
Thanks man!
I finally got hold of my dremel yesterday, so I got to work with the case.
Still just pretty raw "in action"-pics.
First off, I drilled and tapped four holes for the new feet.
http://img94.imageshack.us/img94/2503/58510391.jpg
Insert radiator here!
http://img94.imageshack.us/img94/4079/29782631.jpg
A few cuts later, I didn't have my grinding tools at home so it's a pretty raw cut.
http://img94.imageshack.us/img94/1448/43020890.jpg
A simple cut to the radgrill, so that it clears the foot.
http://img264.imageshack.us/img264/6856/76724707.jpg
Fits quite nicely, but I'm not using this one, it was just for testing before I cut the real thing.
http://img264.imageshack.us/img264/3844/39455810.jpg
The new feet looks so good on the case.
http://img651.imageshack.us/img651/3990/46144721.jpg
Same goes for the back.
http://img714.imageshack.us/img714/2323/68510465.jpg
