6GB OCZ Blade 2000 7-8-7-20 1T
1.) How did the memory die?
Been memtesting all the evening to determine minimum voltages for stability to avoid corrupting my win install. The next day turning the rig on it seemed there were no problems with the sticks at all... they went into windows fine. But then each bench I was starting failed immediately...
2.) What exactly happened?
Things got worse quickly... SPI threw errors, Prime totally quit itself, LinX BSODed. Then memtesting again there was only 4GB recognized. I removed all the sticks testing them individually then. There appeared to be a dead stick #3...
3.) What board, pcb rev and bios version did you use?
EVGA X58 Classified 759, Rev1.0, S21S.
4.) What speed and timings did you run the memory at when it died?
1025MHz 7-8-7-20-88-1T @ 1.67Vdimm
5.) what speed and timings did you run the memory at most of the time?
1002MHz 7-8-7-20-88-1T, 8xxMHz 6-6-5-18-59-1T
6.) What vtt did you run when the memory died?
1.37Vtt iirc.
7.) what vtt did you run the memory at most of the time?
1.32-1.40Vtt.
Greetz,
