These modules can run 06 at 940-950mhz 7-6-5-15-1T 2.25v
Not all dividers/fsb combos are working with the high ln2 speeds.
With conroe at 535-540x10, the memory can run exactly where it needs too. If I can get this quad clocking up to 530 I'm in :D
:shocked:
Hopefully it will get there eventually ;)
Did you try with a tad relaxed "performance level" ? Sometimes seems to help some dividers to clock a tad higher ( didn't thoroughly tested it ) [ but then again, we might have lower performance if the gains from the clocks ain't covering up for the internal chipset latency rise ]
Get well soon and give this CPU + VGAs a proper...OC harassment man :yepp:
thats a sweet 01 result,
cant get over how good theese quads OC, its sooo nice
Hey thanx and good call on the PL's, actually did some of that today. Now just need to test on ln2.
Took out my 3dmark2006 single 8800ULTRA WR by 40 points at 5250mhz on ddr3 lol.
Using about 40mhz less core clock and 30mhz less mem clock on such a gpu bound benchmark(single) too. Could see scores getting near 22k with more gpu power. This one was about all I could handle today :ROTF: :
http://www.overclockingpin.com/21k%2006%20quad.jpg
Can I come over and plug a card in for a few minutes :D
Done deal Sham..."hell is coming to breakfast" :D
24k with default clocked cards, now just to get both cards clocking where they need to be on ln2 and it should be SICK.
http://www.overclockingpin.com/5209%20striker.jpg
Depends on the board really. This one doesn't tolerate cold like my qx6700.
:eek2:
whats your take on ddr3 compared to hi grade ddr2 kingpin looks pretty awesome to me
24k on stock cards.. hihi :D You will take them all! Good luck kingpin!
What a monster. These chips are disgusting, even on dry ice I've seen 4.9ghz '06.
:clap:
LOL that smilie, it fits lol :ROTF:
great job Vince:clap:
edit*
after watching that pic again, it seems you have the road to 27K stil open...
5.3ghz quad and +1000 on the core ^^
:clap: thank you k|ngp|n
Awesome job as always my friend and good to know your recovery is coming along well. I'm sure this really brightened up your day. :)
Good job.
Wow you didn't just break the WR, you smashed it. Next question is whether or not 27k can go down.
Hopefully we'll see some response from the red team tommorow, but will it top 26.4k?
the score is soo sweet,
nicely done¨kp
that thing is rediculous
I think that score is a WR:D Hipro did "only" 26008
Good job :up:
Awsome KP, but you covered GPU clocks :P
Awsome to see you back Vince! :D Scary cpu for sure :)
I cant get any drivers validated on the ORB at the moment so I stoped benching when I noticed. Have e-mailed Nick about it. After a few modification to Blitz I managed to get it running ok. http://service.futuremark.com/compare?3dm06=2801368
