Thanks Vince..... :)
As a matter of fact, I don't believe that this CPU could have done this if I haven't done my "new" mod on AW9D-MAX mobo.... ;)
Well maybe yes and maybe no....On Quad GT it did about 4120MHz before mobo's death...:)
That is a great idea! :up: I often look at the SP-thread because it is a simple way to compare results.
Hipro: I am glad you live in such a warm country. If not, as it looks on your results you would have said 'game, set and match' by now. ;) That is some crazy clock on that CPU.
Sounds good:) Lets get a 3d01 lowclock thread going then??:)
Here is a air result from me. still not much speed on mem yet:)
1.58v on GPU
No OS optimasions or tweaks yet...more to come:)
http://www.2and2.net/files/4657521b39a3d.jpg
Hahah... hipro but how many degrees is in Greece?
4200Mhz is insane....this cpu is strange, my 6800 at ln2 bench to 5500Mhz but air it does not arrive to 4Ghz
Thanks guys.....
Close to the motherboard I had ~22*C....
@ gandalfone: Yes I know what you want to say M8... ;) We have tow IDENTICAL X6800 L631 CPUs here....One does 5400MHz+ 3D under LN2 and the other does 5050MHz....and when I say idendical, I mean identical......ALL numbers of the FPO/BATCH....TWINS .... :)
GOOD idea of a low clock chalange in 3Ds..... One at 3600MHz and one at 4000MHz.... ;)
Yea for some reason my cpu doesnt like to do 4ghz i can bench at 3.98 on air but at 4.0 it crashes no matter what
3DM2001 low clock challenge anyone ? :D
Great work Hipro, I'll see what I can do about that ;)
yea, My old X6800 wasn't too slow.
This is an old run, so stock clocks on VGA. Slow rams, again this wasn't a tweaked run, just showing stability!
http://www.sspmustang.com/OT/x6800/4...-3d01-run1.JPG
I will make some runs with the Quad soon :)
I think ~3970 mhz should be possible!
damn hipro and i thought my E6700 was special :shocked: (well same sort of 1M but max 32M is 4150MHz lol and i've been able to do 3DMARK06 at 4GHz with 1.5v but higher wasn't all that good
what's this new mod you have
Do what you have to do coz now I don't have any VGA to compete on air any more...I've insulated this (second) one too coz official ORB NVIDIA drivers have already been uploaded.... :D
It's sort off "GTLRef mod" but not exactly.... ;) I'll insulate this mobo coz now it performs WAY better than my first(undieable) one.... :D
The BIG joke is that I - yesterday - tested this CPU under LN2 and it goes up to 5070MHz max..... :D Dumn....
I was testing an ASUS Striker last night fully unmoded(default :D ) and uninsulated yet, and my X6800 did ~5340MHz 3D benchable with ONLY 1.86VCore (real).... So I think that if I mod the VCore of it so to get more VCore, I'll be able to bench 5400MHz+ as I do with my trusty ABIT AW9D-MAX mobo.... ;)
Problem is that this Striker doesn't let me play at 1:1 and 1T over 432MHz so I'll have to go with the x13 multi and play my rams at ~625MHz Cas 4-3-3-4.... :( Really bad thing.... Those dumn NVIDIA chipsets are a real pain in the arss... :(
VGA: 8800GTX ES modded 661/1050
CPU: QX6700 ES 3954mhz/1.55v
Mobo: EVGA 680i A1
Yes 1101 ram does work on my card!(I limited myself to 661/1050)
For some reason, the "low clock challange" decided that 4ghz was to hard for everyone to get, here is my attempt with the quad
I want to thank k|ngp|n for all his help :) 3954mhz 3d01 with the quad took time time.
http://www.sspmustang.com/OT/qx6700/...-3d01-run3.PNG
Finished air testing this 512mb HD 2900 XT tonight, totally stock card. 100CFM thru a Tuniq @ 18 C room temp. LOD +4
What I wouldn't give for a working ATI Tool or BIOS editor ;)
http://img.photobucket.com/albums/v3...z_875-9994.png
CPU on Air
HD2900XT stock cooler at 870/998
No real idea what all the tweaks are or even how to tweak so just set LOD at +3 and pressed benchmark on the application.
http://img138.imageshack.us/img138/9...hz71085wa8.jpg
here is mine:
http://aycu14.webshots.com/image/168...7180739_rs.jpg
going to run some more when i get my new cpu, hopefully during this week..
im going to up the vgpu and vmem to, this is with 1.4/2.0V idle..
Swapped CPU's, really need to do the vdim mod on this P5K for some better performance ;)
HD 2900 XT stock cooled.
http://img.photobucket.com/albums/v3...z_870-1160.png
Can I play with some water or is this too cheap for y'alls? (Hey, I think my ATi handicap makes up for it :p:)
http://service.futuremark.com/compare?2k1=9241841
