Give me a little bit and I'll post some suggestions for stable 8GBs
Not sure if my RAM will do that and the board definitely will not. Won't even get to bios with PL 6.
I can get PL 9 stable, but even 8 fails blend at 400fsb. I'll play with my voltages and try to get it rock solid at 400 to so I have a good baseline to work off of. 420 is a sweet spot for my config, if I can get there stable.
Update: got a 1hr blend stable 400fsb, PL9, 1.25vcore, 1.7vnb, 1.53fsb term.
What is the DIMM VTT and where is ti in the bios?
OK, so I'm close to 420 stable now.
Not quite stable yet, although it does load Vista 64. I'd like to improve the performance level ans make this stable and call it a day. Any thoughts?Code:Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : Auto
FSB Frequency : 420
PCI-E Frequency: 100
DRAM Frequency: DDR2-1008
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
8-3-5-4-6-4-6
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
14-5-1-6-6
Write to PRE Delay : Auto
Read to PRE Delay : Auto
PRE to PRE Delay : Auto
ALL PRE to ACT Delay : Auto
ALL PRE to REF Delay : Auto
DRAM Static Read Control: ?
Ai Clock Twister : ?
Transaction Booster : Manual
Common Performance Level [9]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
CPU Voltage : Auto (1.24v) hard setting this causes not to boot.
CPU PLL Voltage : 1.50v
North Bridge Voltage : 1.71v
DRAM Voltage : 2.06v
FSB Termination Voltage : 1.58v
South Bridge Voltage : 1.150v
SB 1.5V Voltage : 1.60v
CPU GTL Reference : 0.67X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
Advanced CPU Configuration:
Everything Disabled
Suggestions are in bold
Extreme Tweaker
FSB Frequency : 420
CAS# Latency : 5
RAS# Precharge : 5
RAS# ActivateTime : 18
Read to Precharge Time : 4
8-3-5-4-6-4-6
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
14-5-1-6-6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5 craps out use(6)
ALL PRE to REF Delay : 5 craps out use(6)
Ai Clock Twister : Moderate
North Bridge Voltage : 1.71v really try to lower this
DRAM Voltage : 2.12v
FSB Termination Voltage : 1.58v This is to high imo
DDR2 Channel A REF Voltage : DDR2-REFF
DDR2 Channel B REF Voltage :DDR2-REFF
DDR2 Controller REF Voltage : DDR2-REFF
Thanks. I suspect I am strong arming the system into booting with the NB and FSB term voltage. I'll make your suggested changes and try to lower those.
Right now I'm on Rampage 0601. I made the conversion just for this chip.
I didn't make Grnfinger's suggested changes yet, but I dropped the buss to 416, dropped the RAm to 1:1, and at PL 9, I've got it blend stable for 90 minutes now. It's either the RAM only being rated at 1000mhz or the divider that was the problem. We'll see how it does, but this RAM never liked anything over 1000mhz. Tony even warned against trying to push it past that as they really aren't binned to do so.
I must say, this chip is a delight! 3.5 no problem, cool as can be and it wants LESS volts. VID on maximus bios was 1.1125, Rampage VID came up as 1.2125, but either way, I think I'll keep this thing for quite a while. Any thoughts on why it wants auto voltage instead of hard set?
I'll make Grnfingers changes and get back to yal'. Thanks for the help.
I noticed you have a PC-8000 ram so 1:1 is your best bet to eliminate ram instability. But at 416, you shoud be able to run PL7, 1:1.
No sig Zucker2k?
Whats ya building???????
I have a i7920 cpu no ram yet nor a mobo, looking hard at the rampage and some corsair
going to build from scratch so I need another H2O setup case psu ect ect... hope to have it powerd up by xmas.
Right now I'm at 420fsb, PL 8. Blend is doing fine for almost an hour now. Should I burn this one in or see how much higher I can go with these settings? I woudl like to hit 450 if possible.
With a Mximus Formula, it's a roll of the dice, but with luck, you should be able to make it.
How low do shoudl I be able to get the PL at this speed?
450FSB PL7 should be the limit
Just wondering...
Is there results of this MoBo going 600MHz on FSB? Does it needs to be voltmoded for this reason?
I need some advice trying to get my ram stable at 500MHz. CPU is stable up to 4.0GHz, so I'm testing it lower (3.2GHz).
Prime95 errors out after 5-10 minutes each time.Code:Extreme Tweaker
- Ratio CMOS Setting : 8.0
FSB Frequency : 400
FSB Strap to North Bridge : Auto (266 IIRC to get ram @ 500)
DRAM Frequency: DDR2-1003
CAS# Latency : 5
RAS# Precharge : 5
Row Refresh Cycle Time : 45
ALL PRE to ACT Delay : 6
ALL PRE to REF Delay : 6
Ai Clock Twister : Tried all settings
Common Performance Level tried 7 & 8
CPU Voltage : 1.35v (reads 1.336v)
CPU PLL Voltage : 1.50v (reads 1.6v)
North Bridge Voltage : 1.59v (reads 1.6v)
DRAM Voltage : 2.08v (reads 2.16V)
FSB Termination Voltage : 1.4v (reads 1.328v)
South Bridge Voltage : 1.10v (reads 1.12v)
SB 1.5V Voltage : 1.60v (reads 1.63v)
CPU GTL Reference : 0.63X
DDR2 Controller REF Voltage : DDR2-REF (reads 1.072v)
Everything Disabled
System specs are:
Maximus Formula (Rampage Mod) 308 BIOS
2 x 2gb G.Skill PC2-8000
QX9650
Dual 4870X2's in CrossfireX
4 x 250 GB Seagate drives (Raid 0/5)
Noctua NH-U12P with dual fans
Thermaltake Spedo case w/five 120mm fans, one 140mm fan and two 230mm fans
Thermaltake 850W PSU
Putting together RII Extreme i7 920 and CORSAIR DOMINATOR 6GB DDR3 1600. Will be moving the Apogee GTZ and PA120.2 over for cooling cpu. Not sure about the NB cooler yet. I'll let you know how everything goes.
And I know this won't offer me any major performance increase in gaming over my current asus builds but hell I'm a bencher
