New Beta Bios F11d for the EP45-UD3P Rev.1.0/1.1
I don't know if it was posted already but theirs a new beta bios F11d out for the EP45-UD3P Rev.1.0/1.1
http://www.station-drivers.com/page/...-ep45-ud3p.htm
http://www.station-drivers.com/telec...ivers.com).zip
Anyone try it yet ?
ET6 on UD3R: "Auto load last save" loads phantom settings
Maybe it's been asked before, but I can't find it ...
Sometimes I set my BIOS overclock settings to a lower FSB speed or higher Vcore than I think the machine will run at, so that I can POST and get into the BIOS in case of a crash. (Note that when you make runtime changes under ET6, thay are not saved into the BIOS, unlike the action of the equivalent but almost-useless Asus AI Suite utility) Then I will set faster FSB/lower Vcore etc. at runtime using ET6. Sometimes I want ET6 to set things automatically at Windows boot time, and I have tried the "Auto load last save on next reboot" option in the right-click menu of the ET6 icon in the system tray.
However, I can't find where ET6 stores the data that it uses when it does the auto-restore. I have saved parameters under the default filename "profile.etf" and other names (on the D: partition, not C: ), but it restores settings from somewhere else that I may have saved many months ago, that are now way too fast for my now tired & aging CPU. Explorer search can't find any .etf files other than the ones I know about.
Where is ET6 getting these phantom settings? The registry? If so, where? Why aren't the settings it uses being updated when I do a save? Anyone ... ?
GIGABYTE GA-EP45-UD3P out of retirement
GIGABYTE GA-EP45-UD3P out of retirement :)
Decided to bring her out for one more round and make her my htpc / lan
so i bought new HAF 912 with a Corsiar H70 " yes I know lame " for a intel e8400
running so far at 4050 stable . . 4 4 4 10 going to push this weekend for 4250 hopefully , is this new bios worth getting ?
System being tweaked :up:
http://i84.photobucket.com/albums/k7...8400at4050.png
New Case
http://i84.photobucket.com/albums/k7...c/IMAG0192.jpg
Outside of Case
http://i84.photobucket.com/albums/k7...c/IMAG0211.jpg
Finished Build
http://i84.photobucket.com/albums/k7...c/IMAG0214.jpg
Close Up
http://i84.photobucket.com/albums/k7...c/IMAG0215.jpg
