no problem.its the same as i use just slightly higher vmch and vtt than my last template i posted
but the mch ref is the same.0.70v in ET6
Some testing that i did with my ex plattform P45 Ud3l and e7400, this really is a nice motherboard and not so expensive :D
The rig
intel core 2 duo E7400
Giga P45 UD3L
Patriot Extreme PC9200
Thermalright Ultra 120A
Cpuz Validation: http://valid.canardpc.com/show_oc.php?id=1253686
Spi 1M:
http://www.pctunerup.com/up/results/...171031_spi.JPG
Wprime 32
http://www.pctunerup.com/up/results/...124_wprime.JPG
Now i would like to take an UD3P with E8600 :D to test it
Sorry was gone working on my build , but try this
[CODE]Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Turbo ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 4.5GHz............................[ 500 x 9.0]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 900mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Turbo ]
Extreme Memory Profile (X.M.P)..................[ Profile1 ]
(G) MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1200 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD[4].........................................[ 3 ]
tWTR[4].........................................[ 3 ]
tWR[13].........................................[ 4 ]
tRFC[68] .......................................[ 50 ]
tRTP[4].........................................[ 3 ]
Command Rate (cmd)[0]...........................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 9 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ 8 ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ 7 ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ 8 ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ 8 ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.1875 ]...................[ 1.4250 ]
CPU Termination [ 1.20 ]...................[ 1.360 ]
CPU PLL [ 1.50 ]...................[ 1.570 ]
CPU Reference [ 0.760 ]...................[ 0.886 ]
MCH Core [ 1.100 ]...................[ 1.460 ]
MCH Reference [ 0.760 ]...................[ 0.901 ]
MCH/DRAM Refernce [ 0.900 ]...................[ Auto ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.200 ]
DRAM Voltage [ 1.800 ]...................[ 2.200 ]
DRAM Termination [ 0.900 ]...................[ Auto ]
Channel A Ref [ 0.900 ]...................[ Auto ]
Channel B Ref [ 0.900 ]...................[ Auto ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ][
anybody have marshmallows , so we cant melt over hoss331 q9550 . . . get some cooling dude
The only reason I have this chip is for dice/ln2 benching so current temps arent really going to matter. The way its setup now is just to make sure it works ok, this being with my old S1283 w/ stock fan and whatever paste I found first.
doesnt matter i have a megahalems and on 1.25 volts im already hitting 65 its just cause i have an immense low vid.. 1.1375 hosses vid is a bit higher but still a hot chip.
yep them low vid chips are hot hot hot:D
Hi guy , back to here for after the year !
Currently I have EP45UD3R
I have change my cpu from E8600 to Q9550 vid 1.200
My ram is limit to not over 1040 MHZ (Crucial ballistix 2x2)@5-5-5-15
And my Cpu cooler may not good enough for OC quad.
Now I can do 450x8.5 = 3.825 MHZ Vcore 1.184(CPUZ) with 1.1 RAM
My temp is quiet high (74,67,72,67)
Do i should change my cpu cooler to archieve 4.0Ghz or more?
Could someone share the setting for OC Quad Plz.
:D thanks for advice Sergio ,just bought TR Ultra 120 xtreme It's have a sell promo in my local country shop. Rightnow I m not set it up in my case yet.
Anyway I play around with it for a while and I doubt that my Quad have FSB Wall Limit around 485:confused: if I reach above that It's freeze while booting to Windows I'm current at BIOS F12. Does it concern with this issue?
but below that should work fine
Are there any trick to hit 500+ Fsb?
anyway this is what I got tonight. set in BIOS and shown in ET6 the temp still high
is it possible to create raid 1 without data loss from source sata drive? when attempting to do a raid 1, the raid utility warns me, that all data (both drives) will be erased:(
thats the problem i have no other drive for backup but some famous czech computer based website wrote, that it was possible
I got the water setup back together so I went ahead and did some test runs on the 9550. Temps are obviously better but im thinking they should be better than they are, or this chip is just that hot.
http://i131.photobucket.com/albums/p...ss281/4300.png
Hoss331 , how much watt consume when you stress your Quad @4300 mhz
,mine now @ 4164 mhz 1.28 vcore consume at peak 133 W when stress very
high compare with duo.
Anyway could you share your bios setting for 500 fsb.
Im on another bord but i guess i just post here cause this is more likely to get reply's haha and i always wanted an ud3p so let me in (A)??
Im now linx stable at 4.165 GHz with a voltage of 1.2 ~ 1.216 load, restarted to oc this cpu cause my old setting stopped to be stable. lets try to get the same speeds as HOSS haha :) (i doubt if i can do that cause of my mobo) my temps under full linx load are 67C with a Megahalems. but under WCG or Prime it doesnt get anny higher than 55C and 58C so i think its ok.
