920 @ 220x19 6GB Memory - Post 1 Of 2
DFI LP UT X58-T3eH8, 02/06 BIOS
i7 920
3x2GB OCZ PC3-15000 Reaper CL9 1866MHz 9-9-9-28
220x19, Memory 1320MHz 6-7-6-21
HT On, Turbo Off
SAPPHIRE 4870 Crossfire
Green Slots Used For Memory
click for larger image
http://www.edgeofstability.com/image...os/main1_s.jpg http://www.edgeofstability.com/image...os/main2_s.jpg
http://www.edgeofstability.com/image...os/volt1_s.jpg http://www.edgeofstability.com/image...os/volt2_s.jpg
http://www.edgeofstability.com/image...ios/dram_s.jpg http://www.edgeofstability.com/image.../feature_s.jpg
Code:
Genie BIOS Setting
Main BIOS Page
Exit Setup Shut down:............Mode 2
O.C. Fail Retry Counter:.........Enabled
O.C. Fail CMOS Reload:...........Disabled
PPM Function:....................Enabled
Turbo Mode Function:.............Disabled
x 1 core Max Turbo Ratio:.........20x
x 2 core Max Turbo Ratio:.........20x
x 3 core Max Turbo Ratio:.........20x
x 4 core Max Turbo Ratio:.........20x
CPU Non-Turbo Clock Ratio:.......19x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings:............Enabled
QPI Link Fast Mode:..............Enabled
QPI Frequency:...................Auto
CPU Base Clock(BCLK):............220 Mhz
Boot Up CPU Base Clock:..........Auto
PCIE Clock:......................100 Mhz
DRAM Frequency:..................BCLK*06 Mhz
UnCore Frequency:................BCLK*16 Mhz
CPU Spread Spectrum:.............Disabled
PCIE Spread Spectrum:............Disabled
CPU Feature
Set VR Current Limit Max:........Disabled
Thermal Management Control:......Enabled
EIST Function:...................Enabled
CxE Function:....................Auto
Execute Disable Bit:.............Enabled
Virtualization Technology:.......Enabled
***** Logical Processor Setting *****
Intel HT Technology:.............Enabled
Active Processor Cores:..........All
DRAM Timing
Channel Interleave Setting:......Auto
Rank Interleave Setting:.........Auto
Memory LowGap:...................1536M
DRAM Command Rate:...............1N
CAS Latency Time (tCL):..........6
RAS# to CAS# Delay (tRCD):.......7
Precharge Delay (tRP):...........6
RAS# Precharge (tRAS):...........21
REF to ACT Delay (tRFC):.........Auto
Write to PRE Delay (tWR):........Auto
Rank Write to Read (tWTR):.......Auto
ACT to ACT Delay (tRRD):.........Auto
Row Cycle Time (tRC):............Auto
Read CAS# Precharge (tRTP):......Auto
Four ACT WIN Time (tFAW):........Auto
Voltage Setting
O.C. Shut Down Free:.............Enable O.C.S.D.F
CPU VID Control:.................1.38750V
CPU VID Special Add Limit:.......Enabled
CPU VID Special Add:.............Auto
Vcore Droop Control:.............Enabled
DRAM Bus Voltage:................1.635v
DRAM PWM Switch Frequency:.......Nominal Frequency
DRAM PWM Phase Control:..........2 Phase Operation
CPU VTT Special Add:.............Auto
CPU VTT Voltage:.................1.32v
VTT PWM Switch Frequency:........Nominal Frequency
VTT PWM Phase Control:...........2 Phase Operation
CPU PLL Voltage:.................1.80v
IOH/ICH 1.1V Voltage:............1.11v
IOH Analog Voltage:..............1.10v
ICH 1.5 Voltage:.................1.5v
ICH 1.05V Voltage:...............1.05v
DIMM 1/2 DQ/DQSTB Bus VREF:......+00.0%
DIMM 3/4 DQ/DQSTB Bus VREF:......+00.0%
DIMM 5/6 DQ/DQSTB Bus VREF:......+00.0%
ADDR/CMD VREF Control:...........Disabled
x DIMM 1/2 ADDR/CMD Bus VREF:.....110
x DIMM 3/4 ADDR/CMD Bus VREF:.....110
x DIMM 5/6 ADDR/CMD Bus VREF:.....110
CPU QPI Drive Strength:..........Normal
IOH QPI Drive Strength:..........Normal
http://www.edgeofstability.com/image...0x19_mem_s.jpg
