well said mate :up:
Can someone post a Bios Temp-let for a Q8400 on a EP45-UD3P Rev.1.0 that could help get me at 4.0mhz I'm running 4 1gig sticks of Micron 555-12 rated at 667 Dram Volt 18000 Cooler Master hyper 212
Sergio is one of the biggest assets to this thread. You may be gone, but not forgotten. R.I.P. my friend.
i dont have a bios template mate but i can give you some tips...btw you know you have a killer mobo ? rev 1.0 can reach amazing clocks
skews
900/900/0/50
set vtt to 1.2 and cpu ref to .785 and mch ref to .80 then up vtt to the value you want letting the other settings change
MCH volts if you are running 4GB set to 1,36
post your actual settings and i will help you better ok ?
cheers :toast:
Sergio
Hi I have this set up, just purchased recently, curious about a few things, ill post specs first, then what i've noticed, then my question(s)... Thanks
E8400 E0 4.264 (533 Fsb x 8) Keeps my 1066 ram times. 1.350v (could go lower?) Runs stable in prime 1Hr, and everything works ok!
EP45-UD3R Motherboard
OCZ Reaper 2x2Gb 1066
OCZ Vertex 30Gb
XFX 5670 (512Mb Non Crossfire ability)
BFG 800+ Watt 4x12v 18A? Rails?
What I've noticed, at 3.6Ghz I could under-volt fine, and run SUPER PI pretty quick, at 4Ghz Even faster! (10-12 Seconds on 1m)
Now.. 4.264Ghz with 1066 ram, lowered timings even, benches higher, but!!!...
With 1Minute + on 1m test? That's getting stupid, how did I go down on PI calculations vs my 3.6Ghz? And such a LARGE variation as-well!
I can Photobucket my Bios screens ....
http://i998.photobucket.com/albums/a...r/IMAG0182.jpg
http://i998.photobucket.com/albums/a...r/IMAG0181.jpg
http://i998.photobucket.com/albums/a...r/IMAG0180.jpg
http://i998.photobucket.com/albums/a...r/IMAG0179.jpg
http://i998.photobucket.com/albums/a...r/IMAG0178.jpg
Thanks for your reply Here's my settings Time to play again anyone want to chime in with some recommended setting to see how far we can bump this up
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .............: Auto
CPU Clock Ratio .....................: 8x
Fine CPU Clock Ratio.................:
CPU Frequency .......................: 3.20GHz (400x9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...............: Enabled
CPU Host Frequency (Mhz) ............: 400
PCI Express Frequency (Mhz) .........: Auto
C.I.A.2..............................: Disabled
DRAM Performance Control
Performance Enhance..................: Turbo
Extreme Memory Profile (X.M.P.)......: Don't have this option in my bios Why ?
(G)MCH Frequency Latch...............: Auto
System Memory Multiplier ............: 2.00B
Memory Frequency (Mhz) .........: 677- 800
DRAM Timing Selectable ..............: Manual
Standard Timing Control
CAS Latency Time.....................: 5
tRCD ................................: 5
tRP..................................: 5
tRAS.................................: 15
Advanced Timing Control
tRRD.................................: Auto
tWTR.................................: Auto
tWR..................................: Auto
tRFC.................................: Auto
tRTP.................................: Auto
Command Rate (CMD) ..................: Auto
Channel A
Static tRead Value...................:
Channel B
Motherboard Voltage Control
CPU
Load Line Calibration (LLC) .........: Enable
CPU Vcore ................... 1.28750V 1.29375v
CPU Termination.....1.200V*..........: Normal
CPU PLL.............1.500V*..........: Normal
CPU Referen.........0.760V*..........: Normal
MCH/ICH
MCH Core............1.100V...........: Normal
MCH Reference.......0.800V...........: Normal
MCH/DRAM Ref........0.900V...........: Normal
ICH I/O.............1.500V...........: Normal
ICH Core............1.100V...........: Normal
DRAM
DRAM Voltage .........1.800V.........: 1.9000v
DRAM Termination .....0.900V.........: Normal
Channel A Reference ..0.900V.........: Normal
Channel B Reference ..0.900V.........: Normal
Advanced BIOS Features
No-Execute memory Protect.......................: Disabled
CPU Enhance Halt (CIE)..........................: Disabled
C2/C2E State Support............................: Disabled
CPU Thermal Monitor.............................: Disabled
CPU EIST Function...............................: Disabled
@Sergio...Congrats and thanks for all the knowledge :up:
OC nub and l0ud_sil3nc3...Some amazing giys you are there :clap:
I'm dying to go to an i7 860 on a GA-P55, but I'm just to damn lazy to have to reinstall all my programs I use.
I wish I knew if some has used Sysprep and switch from P45 to P55 with success on XP SP3.
hey mate to show us your template just put as i did selecting # (Wrap CODE...) from the message menu
u need to setup things as i told youCode:MB Intelligent Tweaker(M.I.T.)
Clock Chip Control
Channel A
Channel B
CPU
MCH/ICH
DRAM
put 1,2VTT and .785 on CPU REF and .80 on MCH REF then UP VTT leaving the values change auto to 1,3VTT
Skews set 900/900/0/50
MCH set to 1,3+ at least
PLL 1,5
check that you have 400x8 not 400x9
also radaja is right you dont have memory with XMP (xtreme mem profile) just put that on AUTO or disable it
cheers :toast:
Sergio
I don't want to sound like a retarded noob but can someone clarify what those above setting mean exactly
VTT = CPU Termination ? yes ? coz theres is no VTT in the ud3p bios
Then your saying up VTT to 1.3 leaving the other values to change automatic ?
not really clear to me is that what your saying ? sorry
then MCH set to 1,3+ at least which MCH ? core ,reference , or dram ref ?
Skews set 900/900/0/50 what exactly are the Skews ?
Can someone straighten me out so i can try these setting please
quick guide to set cpu/mch references using 1.20v vtt in bios
http://i46.tinypic.com/2444b3c.jpg
heres an easy cheatsheet for the actual cpu/mch references
values in bios for different vtt values:helps when assisting
others who are new to the board by being able to give exact
reference values to set for most vtt voltages.
top row represents what easytune6 shows
highlighted green is vtt voltage
highlighted red is cpu reference
highlighted blue is mch reference
EXAMPLE:using vtt voltage of 1.32v
setting the cpu ref to 0.861v in bios(shown in red).
ET6 will show it as 0.785v(1 notch above normal)
setting the mch ref to 0.916v in bios(shown in blue).
ET6 will show it as 0.840v(2 notches above normal)
Code:E-T-6 0.730 / 0.745 / 0.760 \ 0.785 \ 0.800
vtt 1.20 0.730 / 0.745 / 0.760 \ 0.785 \ 0.800
vtt 1.22 0.742 / 0.757 / 0.772 \ 0.797 \ 0.812
vtt 1.24 0.755 / 0.770 / 0.785 \ 0.810 \ 0.825 CPU reference value in bios
vtt 1.26 0.768 / 0.783 / 0.798 \ 0.823 \ 0.838
vtt 1.28 0.780 / 0.795 / 0.810 \ 0.838 \ 0.850
vtt 1.30 0.793 / 0.808 / 0.823 \ 0.848 \ 0.863
vtt 1.32 0.806 / 0.821 / 0.836 \ 0.861 \ 0.876
vtt 1.34 0.818 / 0.833 / 0.848 \ 0.873 \ 0.888
vtt 1.36 0.831 / 0.846 / 0.861 \ 0.886 \ 0.901
vtt 1.38 0.844 / 0.859 / 0.874 \ 0.899 \ 0.914
vtt 1.40 0.856 / 0.871 / 0.886 \ 0.911 \ 0.926
vtt 1.42 0.869 / 0.884 / 0.899 \ 0.924 \ 0.939
vtt 1.44 0.882 / 0.897 / 0.912 \ 0.937 \ 0.952
vtt 1.20 0.720 / 0.740 / 0.760 \ 0.800 \ 0.840
vtt 1.22 0.732 / 0.752 / 0.772 \ 0.812 \ 0.852
vtt 1.24 0.745 / 0.765 / 0.785 \ 0.825 \ 0.865 MCH reference value in bios
vtt 1.26 0.758 / 0.778 / 0.798 \ 0.838 \ 0.878
vtt 1.28 0.770 / 0.790 / 0.810 \ 0.850 \ 0.890
vtt 1.30 0.783 / 0.803 / 0.823 \ 0.863 \ 0.903
vtt 1.32 0.796 / 0.816 / 0.836 \ 0.876 \ 0.916
vtt 1.34 0.808 / 0.828 / 0.848 \ 0.888 \ 0.928
vtt 1.36 0.821 / 0.841 / 0.861 \ 0.901 \ 0.941
vtt 1.38 0.834 / 0.854 / 0.874 \ 0.914 \ 0.954
vtt 1.40 0.846 / 0.866 / 0.886 \ 0.926 \ 0.966
vtt 1.42 0.859 / 0.879 / 0.899 \ 0.939 \ 0.979
vtt 1.44 0.872 / 0.892 / 0.912 \ 0.952 \ 0.992
In case anyone else is looking for a Q9550... MicroCenter has some in stock at the Fairfax, Twin Cities, and Detroit stores.
To bad I live in Ohio:(
just bought this board from radaja at OCN. I would like to prepare early :). Could anyone share their settings for q9650?
Will I need to get this ram? http://www.newegg.com/Product/Produc...82E16820231271
I currently use http://www.newegg.com/Product/Produc...82E16820146785
no need to put those bad attributes on you mate we where all noobs at the begginings...
* VTT = CPU TERMINATION correct
* you go to bios and set manually VTT to 1.2 and set CPU REF on 0.785 and MCH ref on 0.80 then you just move VTT to your desired value lets say 1.3 and you will see the values of REFS you put change auto...leave them
* MCH volts sorry yes to 1.3 and will need more till 1.42 depending on your amount of ram and tight timmings and FSB
* you can find them on ADVANCED CLOCK CONTROL it will help a lot with OC
cheers
Sergio
