Yes it was 1.45V when he lost it but he had been running that same chip at 1.8V on dry ice!!:yepp:
I'm on it... time to push the striker II extreme over its limits again :D
0704 installed and working for me...no obvious changes.
so any ideas if this is the bios we SIIE owners have been waiting for? anyone know whats been changed or is someone going to test it and report back? im away at the moment so cant try this new bios on my board but would like to hear that this is the answer to data corruption!
Hello all
This is my first post here on XtremeSystems, although i've been reading things from here ages ago.
I've got an issue with my Striker 2 Extreme mobo, and i'm just wondering if anyone has/had it, and what is the solution to that problem, if any.
My system is a Striker II Extreme mobo with bios 0507, a QX9650, 2x EVGA 9800GX2, 4 Gigs (4X1 Gb) OCZ ReaperX DDR3 PC3-10666C6, SoundBlaster X-FI Fatality, 4 HDD (2 Raptors as boot up drives for XP and Vista and other 2) and a CoolerMaster 1000W, everything put together with watercooling inside a CoolerMaster Stacker 832, and everything is in stock and in auto.
My problem kicks in either on Vista or XP. Basically i boot into either OS with no problems whatsoever and can do a bit of work, but then the LCD Poster starts flashing weirdly and then everything freezes. Restart, and then it starts again...sometimes it takes 5 minutes, other times 15 or longer...
Again, i am sorry if i've posted on the wrong place, i just hope that somebody can help me.
1. I would run Memtest and see if you have any memory errors.
2. Try 2 sticks of memory on their own, in slots 1&3 (as opposed to 0&2)
3. Check your memory voltage in the bios against the OCZ recommendation.
4. Try without the soundcard
5. Update the bios, 0703 apparently has a lot of CPU fixes.
*NVMM - NVMM 4.082.35
JMB363 OptionROM: 1.06.75
NVRAID ROM: 9.87
BIOS version: 0704 Date:05/21/2008
Checksum: CF00H
1. System don't halt when show keyboard error message. Hide keyboard option at halt on item.
2. Modify crashfree function behavior. System don't halt when legacy floppy don't find.
3. Patch Wolfdare 2.66G/1066MHz (E7300) CPU VTT to 1.30V , Vcore to 1.40V when OC
4. Add P790_War_Support. (NV-NEWS 052008)
5. Update NVMM 4.082.35
** Micro Code Information **
ID CPUID |ID CPUID |ID CPUID |ID CPUID
2C 0F25 |17 0F34 |17 0F41 |05 0F43
06 0F44 |03 0F47 |04 0F4A |03 0F49
04 0F64 |0A 0F32 |02 0F37 |05 0F60
07 0F61 |0F 0F62 |0B 0F65 |A3 06FD
B6 06FB |82 06F9 |68 06F7 |CB 06F6
5A 06F2 |33 06F5 |33 06F5 |26 06F4
38 0661 |04 0660 |06 0671 |06 0671
06 0671 |0B 0676 |0B 0676 |03 0677
B3 06FB |
It do have NVMM the same as P05 for reference eVGA do. I'm not sure whether this corrects all the problems with corruption.
Hey Tyke,
Just came back from the Asus support site, you malicious bad person you :rofl:
I guess some people who don't know how to properly flash a bios file got their hands on some beta releases and nuked their boards..
And that's your fault!!!!!
Anyway flashed 0704, cleared cmos and reloaded parms discussed in my earlier post, and all seems ok.
I'll rock and roll for a few days and czech (sic) back.
0704? So has anyone who has had problems got it to FIX they're SLI lockup issues OR their non SLI DX10 lockup issues?
hi all ,i want use EZ update 0704 BIOS but can not! can i help me? thank you
You need to flash to 0508 or 0512 and then try EZ-Flash to 0704.
not work! i use EZ-Flash or XP Flash but Still had not responded
look its
http://i296.photobucket.com/albums/m...001_2008/b.jpg
You'll have to use AWDflash v1.33 to update your BIOS to 0704.
It's pretty easy.
Just make a bootable Floppy/CD/DVD with it and the BIOS image and once you boot with it, type AWDFLASH BIOSNAME :)
Thanks bro :D
Im just trying to get my pc ready for the next 3-4 years you know. Between 2006 and 2008 I spent too much money on this pcs (Striker+Striker 2=$800 :eek:) so I really want to get this thing estable and since is the best motherboard out there (talking about specs) I want it to be estable :) and I finally did.
I was about to say it was getting too late :p:
Gonna go check what tyke is doing over there :rolleyes: have been so busy OCing my system I couldnt even check ASUS forums :P
Ok, I didnt come here for 1 day and when I come I see 20 new answers and a new BIOS. It seems like you guys do your stuff when Slim is not here hmmm...:rolleyes:
First, can somebody tell me what in the world does #4 mean?
What is this? War support, hahaha :rofl:, seriously, what is this?
Another upgrade to the NVMM, nice :)
And just want to mention, have you guys noticed this BIOS was released on the 20th... so there might be another BIOS on the way probably really soon?
I have been running 0703 stable linked and synced at 1610mhz for the last little while. I have been trying to run 1770 linked and synced but Prime95 frezzes after test 4 or so.
Flashed to 0704 couple of hours ago 1610 is still good sfc ok prime ok no issues. Cranked it upto 1770 linked and synced..prime is failing. I loosened the ram timimgs to 8-9-9 28 and found prime was lasting longer but still failing.
Figuring this OCZ ram is probably the problem I just unlinked and set FSB to 1810 and put the ram back to 1610 which has been stable. Prime95 ran for 22 mins no freeze(not that this indicates 100% stable but it seems good so far) here are the settings, which I got mostly from reading Homer and BenchZowners threads..I will take no credit or responsibility :)
Multi: 8
FSB-MEM: Unlinked
FSB: 1810
MEM: 1810
Memory timing:
P1: Enabled
P2: Enabled
7-7-7-21 2T
All subtimings Auto
Overvoltage settings:
CPU: 1.4
Loadline Calibration: Enabled
PLL: 1.5
VTT: 1.30
MEM: 1.92
NB: 1.46
SB: 1.55
GTL_REF0: -29
GTL_REF1: -32
GTL_REF2: -32
GTL_REF3: -29
NB GTL_REF: +40
DDR3 REF volts all Auto
Screen shot.
http://img56.imageshack.us/img56/782...8fsbsi7.th.jpg
hi all, can i give me AWDflash v1.33 ,I could not find
Bah, freeze with 0704, going back to 0703
