Prime95 Blend test on VISTA 64 bit
Hi, all.
Finally, found some time to set up the new mobo with all the rest.
My first impression of the board is great, after using P5N32E-SLI for 6 months with QX6700 trying to OC :shakes: .
680I is a great gaming SLI chipset but far not the best Quad overclocker – IMHO. I could only past 330-340 FSB on my QX6700 (B1 SE).
DFI P35-T2R reminds me (like many of us I guess), the old good DFI Expert 939 horse - nice & solid :up: .
Back to the problem :confused: .
On my stand board assebling, I had a dual boot - XP SP2 32bit with Vista Ultimate 32bit. All the benchs were made on the XP OS till I stopped on 470*7. After reinstalling the raid massive, I decided to install Vista Ultimate 64 bit to work with. Everything looks good up to date, till I decided to re check my overclock stability and raise/low the settings.
As mentioned all the previous settings were made in the bios while testing/benching on XP prior to reinstalling the new RAID0. Now only Vista Ultimate 64 bit is installed.
Vista Installation , SuperPI ~32Mb, 3DMARK 03/05/06, Lost Planet DX10 19x12 highest settings gameplay for hours, Everest Benchs all are good and stable.
Prime95 is my problem. I Cannot run Blend Torture test under VISTA 64bit. The SmallFFTs is hours stable.
Earlier, while benching Blend on XP, it was not stable at more than 333/667 (1:1 940Mhz) on 5-5-5-15 with my crucial on reasonable VDIMM. So I left 940Mhz 5-5-5-15 till the next long overnight reading/testing and Blend bench was OK on XP with 2.27 VDIMM.
On Vista 64bit I already tried P642414,P64v254 – after running the blend test, the memory usage raises up to 2GB maximum according to the resource monitor, and the PC completely freezes after a couple of seconds/half of a minute. I tried to lower the FSB – still completely freeze after a bit longer period – a minute or less :mad: .
I guess it might be a software problem, not the overclocking instability, or maybe there is a trick using prime under VISTA 64Bit I do not know about…
Rest of my rig :
DFI LanParty UT P35-T2R
QX6700 (B1 ES) @ 3.29 GHZ (470*7) on water
2GB Crucial Ballistix Tracer PC8000
Point of View 8800GTX (no OC)
Creative X-FI Elite Pro
2x36gb WD Raptor Raid 0
2x250Gb Seagate 7200.10 no RAID
LiteOn LH-20A1S 20X SATA
Antec Trio 650W
Antec Nine Hundred
Samsung 244T
CPU VID: 1.45v
Special ADD: AUTO
SB: 1.07v
VNB: 1.57v
CPU PLL: 1.75v
CPU VTT: 1.6v
VDroop: Enabled
Clockgen: 3.60v
GTL: DISABLED (110/110/110)
Any help is appreciated. I do not want/need another OS on my PC right now, for that reason I did not install XP in dual boot.
Best Wishes!
P.S. SRY for my poor English ;) .
