Originally Posted by
shazza
Just reporting back that Waterlogged's hint worked wonders. I was able to squeeze, twist, and pull it off*. Only difference is, mine came completely out of the back housing, as there are two additional screws holding the bezel to the "works." No issue to remove those and pop it back in the case (minus bezel). Yay, one problem solved, many left to go. No pics ... been busy practicing my jigsaw skills and more hours re-doing tubing layout and cabling. The Cpt's success with the router has me re-thinking, pondering, puzzling, and in a daze.
*edit - umm, I was speaking about the bezel on the little USB monitor.
