Can you help me to overclock my q6600 (G0) on a gigabyte ud3r ?
I used the settings bellow , i am blend prime stable for 5hours and then it errors.
I need your advices on how to finetune the settings e.g. adjusting voltages or gtl for getting stable without the need of increasing vcore.
Here are my current settings :
Code:
Q6600 450*8 3600Mhz
Robust Graphics Booster [Auto]
CPU Clock Ratio [8]
**********Clock Chip Control***************
CPU Host Clock Control [Enabled]
CPU Host Frequency (Mhz) [450]
PCI Express Frequency (Mhz) [101]
C.I.A 2 [Disabled]
*********Advanced Clock Control**********
CPU Clock Drive [900mv]
PCI Express Clock Drive [900mv]
CPU Clock Skew [0ps]
MCH Clock Skew [0ps]
*******DRAM Performance Control********
Performance Enhance [Standard]
Extreme Memory Profile (XMP) [Auto]
(G) MCH Frequency Latch [Auto]
System Memory Multipler [2.40B]
Memory Frequency [1080]
DRAM Timing Selectable [Manual]
CAS Latency Time [5]
tRCD [5]
tRP [5]
tRAS [18]
*******Advanced Timing Control***********
tRRD [8]
tWTR [8]
tWR [8]
tRFC [70]
tRTP [8]
Command Rate (cmd) [2]
***********Motherboard Voltage Control*******
Load-Line Calibration [Enabled]
CPU Vcore [1.4] (1.376 Windows)
CPU Termination [1.38]
CPU PLL [1.59]
CPU Reference [Auto]
MCH Core [1.3]
MCH Reference [Auto]
MCH/DRAM Refernce [Auto]
ICH I/O [1.50]
ICH Core [1.2]
DRAM Voltage [2.1]
DRAM Termination [0.90]
Channel A Ref [0.90]
Channel B Ref [0.90]
Channel Timing Settings
Static tRead Value [10]
tRD Phase0 Adjustment [0]
tRD Phase1 Adjustment [0]
tRD Phase2 Adjustment [0]
tRD Phase3 Adjustment [0]
tRD 2rd (Differnt Rank) [8]
tWR 2wr (Differnt Rank) [8]
tWR 2rd (Differnt Rank) [7]
tRD 2wr (Same/Difft Rank) [9]
Dimm 1 Clock Skew Control [AUTO]
Dimm 2 Clock Skew Control [AUTO]
DDR Write Training [AUTO]
Channel Driving Settings
Drive Strength Profile [Auto]
Data Driving Pull Up Level [Auto]
cmd Driving Pull Up Level [Auto]
ctrl Driving Pull Up Level [Auto]
clk Driving Pull Up Level [Auto]
Data Driving Pull Down Level [Auto]
cmd Driving Pull Down Level [Auto]
ctrl Driving Pull Down Level [Auto]
clk Driving Pull Down Level [Auto]
*****************Advanced BIOS Features*********
CPU Multithreading [Disabled]
Limit CPUID Max to 3 [Disabled]
No-Execute memory Protect [Disabled]
CPU Enhance Halt (CIE) [Disabled]
C2/C2E State Support [Disabled]
C4/C4E State Support [Disabled]
CPU Thermal Monitor [Disabled]
CPU EIST Function [Disabled]
Virtualization Technology [Disabled]
Thanks.
edit : I use 2x2gb corsair dominator 1066.
