Originally Posted by
Seanie's Show
I know exactly how you feel, my G0 stepping quad posts and boots to windows vista at 3.8-3.9ghz, but I am struggling to get it stable anything over 400mhz FSB on this board (3.6ghz), upto 400mhz I have the following settings and will blend prime all day and all week with my crucial ballistix 667mhz at 1000mhz:
CPU = 1.45v, RAM = 2.23v, FSB VTT = 1.38v, NB = 1.45v, SB = 1.15v, GTL's all currently Disabled, Clock Gen = 3.45v, mem is running at 4-4-4-12 @ 1000mhz.
However even at 401 FSB everything becomes unstable, I just dont get it, i've tried bumping up voltages etc and it doesnt seem to make any difference, im not willing to run the NB at 1.6v 24/7 as it already gets hot enough (47oC with a fan on it whilst blending).
I was testing memory earlier in case that was the problem, and the memory was stable no matter what dividers I used all the way upto 1000mhz 4-4-4-12, some of this testing was done with the board and the CPU at stocks, others required the FSB moving up and the multiplier on the CPU dropping to keep the CPU at stocks, but once again, the minuite I pushed the FSB over 400 it was failing memtest again, I think the setting I had on the ram at the time was 333/800. at 400FSB it was at 960mhz so I pushed the FSB to 416 to put the ram at 999mhz (1000mhz) and like I said it was failing memtest.
Below is a kind of review I just typed up for myself to keep myself in check, so I knew what I had tried and what I had'nt, feel free to download it and have a look, then hopefully someone might be able to answer both of our issues.
