i use the same just use a card to place a thin layer over the chip
I wonder if ambient at 85 to 86'F is the culprit. Hot nights in Puerto Rico is killer, now with a/c at max got it down to 38'C idle.
Quick Question - I've been running my E8400 at 4.0GHz at 1.2vcore on my P45-UD3P since I received the components, and I've never updated the BIOS on my motherboard. It's still running the F4 BIOS! Are there any advantaged to update to the latest BIOS? I've never messed around with updating BIOS's before, that's why I'm asking.
Thanks NoGuru, that's what I figured, just wasn't certain on the issue. Cheers
nice system u have there
a friend of mine will come from the states in about two weeks ... I have Cooler Master HAF922 and wanna make a water cooling loop for the cpu only
can u make a list off the components used in your water cooling gear with links? the same request for andresergio
please provide some links from where and what to get
for andressergio: how is named that distancier between the radiator and the case and the support that holds the reservoir that clears the bubless from the loop? where can my friend order them from? (he is in the states now)
with respect
kagula323
Pump http://www.sidewindercomputers.com/swmc12vdcpu.html
Pump top, "optional" but helps performance. http://www.sidewindercomputers.com/ekwaekxforla.html
I have 10 feet of hose http://www.sidewindercomputers.com/fetuftacuvho2.html
tube cutter, but not necessary http://www.sidewindercomputers.com/kwadtucubl.html
RAD http://www.performance-pcs.com/catal...ducts_id=25389
RAD box http://www.performance-pcs.com/catal...ducts_id=25631
Metal clamps http://www.performance-pcs.com/catal...ducts_id=25625
Fan controller http://www.frozencpu.com/products/96...?tl=g34c17s286
Fans http://www.petrastechshop.com/12yalod1cafa1.html
PT Nuke http://www.petrastechshop.com/peptpcobi1.html
Res http://www.sidewindercomputers.com/swmcmire2re.html
That should cover it. I have an Enzotech CPU block, EK NB block, and a Koolance GPU block, because they where all used.
Hope this helps.
Thanks NoGuru :up:
kagula you can check my HAF922 watercooled worklog if you want here
http://www.xtremesystems.org/forums/...=249147&page=3
Cheers :up:
Sergio
well I finally got around to playing with this X3380 some more and it isn't as bad as I thought, well it loves volts but it is a freakishly cool running chip.
http://i45.tinypic.com/2gwt6j5.png
that was on air with a lapped TRUE w/ two San Ace fans in push pull. I can't wait to get my socket 775 backplate for my Apogee XT:)
Seeing some nice clocks with the USB3P - mine's not far away apparently so I'll be joining you soon. Just one thing - I'm assuming as it's P45 the ram straps are just same and you just use higher rated dividers (e.g 2.66c e.t.c)?
lo guys
i just got this on the mail yesterday (thanks T :up:)
http://img198.imageshack.us/img198/2739/p10405941.jpg
needed some MCH to do rated 1600 6-9-6-24 but stock vdimm
1600 6-9-6-24 @ 1,65 stock vdimm
http://img35.imageshack.us/img35/976...cr2hyper32.jpg
and as im new on DDR3 and im on a P45 chipset, this mem are for P55+ i though that for 2000 9-9-9-24 1T will need more volts...i was very wrong i needed LESS MCH and vdimm to pass wich is the first time i see this
2000 9-9-9-24 1T @ 1,62 vdimm
http://img35.imageshack.us/img35/755...cr1pl8hype.jpg
http://img401.imageshack.us/img401/4...cr1pl8ever.jpg
Thanks zsamz_ for the help :up:
Cheers :toast:
Sergio
Cheers mate, good to hear all the dividers work ok, lots of flexibility is nice! Can performance levels go any lower or is it FSB that determines that more than divider?
Cute kid btw :D
Umm, I getting jealous of all the USB3P going around! Grats on the new board In-Fluance.
Love your new Ram Serg!
Hey influence !
***Yes they work all need diff settings but its supposed to be like that, im happy now that i found that i dont need higher volts to make it go on 2000 1T...will reduce latency will try 2000 8-9-8-24 and 2000 7-8-9-24 and see what i can do, kit arrived yesteday and thats are my firsts test
***I think that PL8 with the quad at 4500 and 2000 its some limit but i need more ppl to test that so join the USB3P club :)
Cute kid btw :D
***Thanks my we are really proud of Valentino its 2,5 month now but looks like 4 lol
Cheers :up:
Sergio
Those are some very nice clocks on your new board Sergio, and cute kid as well! :up:
Nice going Serg...for both the clocks and the kid !!!
damn Sergio getting us all jealous with that new board and ram here... looks likea lot more fun for my q9650 soon :)
that memory is very nice andres, I am very glad to see DDR3 2000 on a P45 mobo, and whats crazy is it took less MCH voltage to run at higher speed with looser timings.
