sure can be some bios tighten timmings more than others...for ex F10B best bios and thigh timmings...but F10 has some new features and looser timmings wich for some can be good, im using it with no problems just re test
Cheers
Sergio
http://i39.tinypic.com/2a6s0oh.png
this is on the EP45T USB3 with DDR3
its hot here today, it should be much cooler in a few hours
also my UD3P might be for sale along with my GSkill 1100's.
Either way this is a great board for any one that still likes to play with socket 775.
sorry about that that is a bit small here is a better one. . .
http://i41.tinypic.com/2a78qqv.png
I have stuck sensors on cores 0,2,3
I can't wait to put this chip under water:up:
What are the dividers I should be using? I have some Kingston HyperX DDR3 2000 c9 if that helps. Also what MCH voltages should I be using?
3.20B still has pretty decent bandwidth and at that speed I would think you could at least run it at cas7.
Did a quick bench today. http://valid.canardpc.com/show_oc.php?id=1151229
Nice work NoGuru, nice low voltage for that speed.
Could anyone tell me how low the voltage goes on the EP45T-USB3P please? I'm looking at a pair of G.Skill Eco's rated at 1.35v (although 1.5 is ok apparently), and was wondering if the board goes down that far?
I was just looking at my options, speed isn't so important to me when it comes to ram although I might consider some better sticks at some point. They just seem like a good price, they look ok, and they can o/c reasonably well, plus the fact that they're g-skill is alway a plus in my books! So no info on the ram volts then? I'll have to take a peek in the manual - see if it's in there ;)
My T board goes down to 1.15 then 1.25, 1.35, 1.45, 1.50, 1.56, 1.58, ect, so you should be good.
That's reassuring to hear, thanks. Just waiting for the parts now. First will be my rad, but the board wont be with me for another week at least, so I'll fit & test the rad & see how things move along, hopefully this will replace the weakest link in my loop..
I will have a Xeon X3380 here tomorrow:D
l0ud_sil3nc3,nice ,looking forward to your results
