Originally Posted by
Sam_oslo
Just 2-3 degrees different, and all my case-fans spins at ~60% that can add to it, but temp-difference is not a big deal. I'm more concern to know about the real different in power-usage, and mentioned temp because it indicates power-usage, but the temp in not a big deal by itself.
Cores are very responsive, they jump up and down real-time. I'm using manual vCore, with LLC=Ultra, and the it's 1.288v/1.272v (Idle/Load). No stability issue at all.
If you want low voltage at idle, then you have to use oftest mode, but I personally haven't used it, and don't know much about it.
