Thanks :D I just pushed her to 3.8 last night, and I'll go higher when I return from my parent's on Wednesday :up:
Thanks :D
Im hoping to start a new project in the new year, Fancy having the Black Album snake laser cut into the side of my "new" case.
sorry for low resolution
http://i3.photobucket.com/albums/y71...MG_3745jpg.jpg
http://i3.photobucket.com/albums/y71...MG_3746jpg.jpg
(Their is 7.1cm of clearance)
I need to give it a go-over with a can'o air ^_^
Like the look of the rig Binormalkilla.
Yea he has that Swiftech Radbox. I'm really that the Radbox is sturdy enough to hold that 480GTX......because I would've had to fabricate a bracket for it if not.....there isn't any way it would fit in my case without relocating the SATA cage and the top 5.25" cage.
I wish I could have mounted the top of the rad flush with the case....but as you can see that isn't possible with the location of the 120mm exhaust case fan.
I may look into drilling some holes....
I still have to take my dremel to the top fill port hole and widen it......looks like crap with it poking out like that:rofl:
Just like to say merry christmas everyone. Have a good One! :up:
http://farm3.static.flickr.com/2047/...35637701_b.jpg
Still using plain distilled water.
Going to use my G11 + Biocide mixture once my FuZion nozzles come in and I find the best nozzle to use.
And if it's a Q6600? Use the quad nozzle right?
Can some one tell me where SiNiSon got his sATA cables from? I mean I found the one website someone posted but I live in the US and it doesn't have prices for the US and I can't ship to the US.
P.S. Everyone Murderbox.com is up... check it out! I guess he is selling his mod to anyone who wants to buy it! I can't get the pictures to come up... but still impressive none the less
http://usera.imagecave.com/sstrokerace/DSCN1705.JPG
That's it, no pics of the inside unless you want some. Just a simple unit that I'm running in my sig.
new toy :) all in the same loop
Orthos + Atitool stressing stable
Cpu E4300 @ 3600 ( 400 x 9 1,6 Volt )
Vga 7900gs @ 700/800 Vmoded ( Vdimm 2,35 Volt/ Vcore 1.55V )
Cpu temp 40 *C
Gpu temp 42 *C
Board temp 27 *C
with Orthos ( blend ) and ati tool ( scan for artifacts ) running until all the component reach the max temps
http://img214.imageshack.us/img214/1...1844cj1.th.jpg http://img293.imageshack.us/img293/6...1845oe3.th.jpg http://img177.imageshack.us/img177/2...1847jy0.th.jpg
murderbox.com is up, OMG my eyes :eek:
Dude, murderbox is stinkin sweet!!!!!!!!!
Nicely designed site: as thoughtful and well executed as the rig it pimps...nice:up:
Got rid of Feser One Liquid (it sucks) and added a mcres :)
Before
http://img123.imageshack.us/img123/6...stomfn0.th.jpg
And
http://img57.imageshack.us/img57/342...stomdz1.th.jpg
After:
http://img177.imageshack.us/img177/2...argeig6.th.jpg
http://img165.imageshack.us/img165/9...argeum3.th.jpg
Looks sweet trouble!
Very clean! :up:
http://ceemic.pri.ee/vesi/water18.jpg
Other pics: http://ceemic.pri.ee/vesi/
Updated from:
Watercool HK rev2.5 -> FuZion
Alphacool AP700 -> MCP655
custom reserv -> MCRes-Micro
8/11 tub. -> 9/13 tubing
http://ceemic.pri.ee/vesi/vana/
Also used 2 copper elbows, 12mm diam.
Coolant is Zalman ZM-G200
:cool:
