Originally Posted by
Drwho?
Well, you assume that I am incorrect, I know you are :) ... I did put the stuff on the table, I told you, I tried a permutation of codes to figure out how large the decoding capability, and i ended up with 2 IPC per thread ... :rofl: sorry ... If you had a part, you would end up with the same number , you can throw at me as much Powerpoint persentations as you can, you are not going to change my mind. :up: :clap:
you are free to trust your powerpoint presentation, I don't mind, you are just a little bit too quick to say that somebody is wrong, without even a part in your hands ... don't you think it is a little too much?
PS: Yeap, you can design code to figure out the specs of a CPU, it is a nice practice, you should try.
With Respect,
Francois
