Originally Posted by
richard_crl032
Hi Holmer,
Thanks and appreciates your direct post for my request for assistance.
I updated to bios 0602 and while there seems to be some improvement, the system is still unstable especially when LLC is at Performance.
Noted that you went back to SB@1.02 for my similar setup with 4870X2 Xfire and I will do so as well in my continued attemp. I did thought of going to Rampage Extreme as it seems popular and presumably stable but I will tap on your experience to avoid it. X58 no longer seems interesting as I am quite fed-up with such so-called highend mobo which do not seems stable for OC despite the enthusiasm in the OC community. Watercooling stuff is out of the question as my system is meant as HTPC in my bedroom with the occasional gaming but primarily just to do the usual stuffs of surfing, work etc. The only "stable" option now is to disable EIST and run stock at 3.33GHz for my e8600 with stable prime for >12 hrs and also IBT stable for 6 loops but OCCT fails within 30 minutes. Good thing is that casual gaming, 3Dmark vantage/06 etc. and usual usage is "stable" without the usual freeze at startup and occasional BSOD .......
My 2 kids' system with Asus p5w-dh and e6600 had clocked stably for >1 year at 3.2GHz i.e. 33% which led to my current disappointment with the p5e64 after the good experience and I now appreciates some hardcore Ocer who sold out their latest gig and commented that current mfgrs are just pushing their products with promises on performance, including OC, without actual performance. No sure if the graphic aspect of just having single 8800gtx has anything to do with my current system with the 4870X2 Xfire.
BTW, can you elaborate on GTL CPU and NB to have some educated adjustment or do I have to try by luck which is excruciating and I will certainly avoid future mobos without at least temp/voltage monitoring on NB, SB etc. since using multi-meter etc. does not appeal to me.
Last but not least, I wish to thank you again as you are the only respondent to my queries despite also PMs to those who posted here and using the Wolfdales ........
Regards,
Richard@Singapore
