Well couple issues i have with his testing. Lack of stabilty tests used...
Prime x370 pro i have tested with 4 chips 2933 is max stable in prime 95 80-90% ram allocated custom blend test. 4 sets of memory tested...20 min tops...= fail...rounding errors..even with stock cpu speeds..
The same memory running 3200 14-14-14 with 32gb....or 16gb configs fine on taichi and ch6 pass stability testing.
All can "run" @ 3200 in benhmarks...
Lack of SOC and vdimm mentioned...
I have yet to determine the why....the board is a thorn in my side...great board other than that issue...prime b350 plus...same issue...interestingly the pwm for memory is almost identical minus one fet....coincidence?
gaming 5 was stable @ 3200
