alright.. well youve only done step 1
read/look thru the 3 step vgpu mod post:
http://www.xtremesystems.org/forums/...&postcount=237
step 2 - pencil gets you more.. or replace the resistor with a 500 ohm vr set @ 300 ohm
step 3 - 500 ohm vr set @ 200 ohm gets you more/closer to the 1.39v limit
if the bridging of the vids is done properly you can get ~1.39vgpu
once you reach above 1.3vgpu you
gotta perform crotales ocp mod.. start @ 10k ohm vr and if you have to lower it.. you can go as low as 1k ohm no problem
all together it mounts to 4 steps
benefits of the 4 steps ? if all 4 done properly you wont lose any mem clocks.. youll gain core shader and mem clocks
cheers :toast:
