Originally Posted by
drnick79
I have had the most stability at 450 fsb using the 266/667 strap with 2x2gb sticks of gskill 1066 ram at 5-5-5-15...these settings yield everest read scores of about 9600 and latency values about 50.1. The NB voltage is about 1.5v. I'm watercooling both the CPU and the NB.
From a memory performance standpoint, are you guys saying I would be better off using the 333 or 400 strap? If so, I assume I would need to turn down the NB voltage a bit too? I have had difficulty getting the 333 and 400 straps to runs stable.
I'm just a novice -your advice is appreciated!
