EAAEE
heres is my latest.very pleased with memory performance so far.
http://i39.tinypic.com/2hn5hzb.jpg
http://i35.tinypic.com/zmhxqx.jpg
Code:CPU Feature Page
Thermal Management Control................Disabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Disabled
Execute Disable Bit.......................Disabled
Virtualization Technology.................Disabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................8x
CPU Clock.................................530 MHz
Boot Up Clock.............................Auto
DRAM Speed................................333/800
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.381
CPU VID Special Add.......................Auto
DRAM Voltage Control......................2.3V
SB 1.05V Voltage..........................1.070V
SB Core/CPU PLL Voltage...................1.55V
NB Core Voltage...........................1.53V
CPU VTT Voltage...........................1.15V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................N/A
CPU GTL 0/2 REF Volt......................N/A
North Bridge GTL REF Volt ................N/A
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................5
Precharge Delay (tRAS)....................15
All Precharge to Act......................Auto
REF to ACT Delay (tRFC)...................30
Performance Level.........................7
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................Auto
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Auto
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current
DIMM 2 Clock fine delay...................Current
Ch 1 Command fine delay...................Current
CH 1 Control fine delay...................Current
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current
DIMM 4 Clock fine delay...................Current
Ch 2 Command fine delay...................Current
CH 2 Control fine delay...................Current
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
zsamz,i dont have a dmm right now,so say im using vtt of 1.15 what would you suggest i should set in bios(to get 60-63%)to start with?ranges for trial and error that i can use for all three GTL's,the two cpu's and the NB?
thanks.
500 FSB would be awesome!
Alas I m using non-QVL RAM and someone else from XS told me it might be D9GKX.
Any much higher-430 to 440ish and I fail memtest #5 right at the very end of test even with PL 8 and NB volts up to 1.5:eek:
Is this indicative of having to master the read delay Pulls?
I had fun with my old chip:D I am currently running an E8500.
The chip in my Sig is actually a Cedar Mill Die which is half a late-Gen Pentium Dual-Core or a Presler Die. The 6X1 series was the one with 2MB of cache instead of 1MB like Prescott so in other words I actually had a chance playing Crysis on high:p:
The 631 model in specific Set the world record for Raw Speed Clocking in at about 8.1GHZ:shocked: on LN2 so I thought-why not-maybe I could pull off 5.0 on Air?Nope. But Max 4.5GHz@1.45V/15=301FSB*3.34=1003MHz DDR
PL 3 wasn't bad either-I got 50% OC! I kicked in the full 2:1 A couple times for 1200 and got R-9512 and t-68.3 with that setup but It wasn't really Gaming/Prime stable and I was already at the Chip's FSB wall anyway. It was swell but the swelling's gone down:p: So I got E 8500!
I am inspired now to see if I really can go higher with my E 8500/RAM/Mobo Combo when I have some free time.
***SIG Update***
E8500 Vid 1.25V Q820A966 @4.012GHz/9.5=422FSB*2.4=1013 DDR 4-4-4-10
Vcore 1.26V VMem2.316V VNB-1.37V VTT-1.12V GTL- 57-57-83 tRD 5
Everest R-9276 W-8953 C-8604 t-54.5nS SuperPi 1 Meg-11.281S
NewEgg has dropped its price on the UT P35: http://www.newegg.com/Product/Produc...82E16813136037
Hello,
I have some problems whit this mainboard (bios D317) and an Intel q9550 c1
I can't go to 400fbs even if i downclock the cpu to 2800 (400 x 7) whit default vcore
I have tried some setting but nothing worked (vtt, vnb)
prime95 (blend) give me error in few seconds, sometimes even at default speed at 333fbs... my ram are ok (gskill hz ddr800)
Any advice?
using the 5:6-333/800 divider with this board,on pl7 where does the fsb top out at?can it go say 560fsb pl7 w/5:6?
well i just got 540x8 ddr1300 5:6 pl8 stable,so i tried pl7 and it seems stable.thats why i asked because when i was at pl8,i didnt want to try pl7 till i found out but i couldnt wait.i left the aggressive things on auto for pl7.now im going to lower the vcore and try setting it to more aggressive.
http://i39.tinypic.com/264qt14.jpg
http://i44.tinypic.com/2upzbig.jpg
push a little more i'm sure u can break 12k:yepp:
im trying.i got to say this is a sweet board.
My UT P35 is great on open bench, but I decided to put it in my main system in place of the DK X48 and now 500x8 with RAM at 600 (my 24/7 settings previously) doesn't even want to past Memtest. :shrug: My whole reason for swapping was seeing 500FSB with PL7 and More Aggressive being stable, and I benched with those settings and it seemed fine, but not so in the case with all my hardware. I thought something was up with the DK X48 not being able to use More Aggressive with 500x8 5:6 PL8, but I guess it wasn't the board, but something with my loads of components.
Code:Genie BIOS Setting:
Exit Setup shutdown....................... - Mode 1
CLOCK VCO divider......................... - Auto
CPU Clock Ratio........................... - 8 X
CPU-N2 Ratio.............................. - Disabled
- Target CPU Clock........................ - 4000MHz
CPU Clock................................. - 500 MHz
Boot Up Clock............................. - Auto
DRAM Speed................................ - 333/800
- Target DRAM Speed....................... - DDR2 1200
PCIE Clock................................ - 100 MHz
PCIE Slot Config.......................... - 1X 1X
CPU Spread Spectrum....................... - Disabled
PCIE Spread Spectrum...................... - Disabled
SATA Spread Spectrum...................... - Disabled
CPU Feature:
Thermal Management Control................ - Disabled
PPM(EIST) Mode............................ - Disabled
Limit CPUID MaxVal........................ - Disabled
C1E Function.............................. - Disabled
Execute Disable Bit....................... - Disabled
Virtualization Technology................. - Disabled
Core Multi-Processing..................... - Enabled
Voltage Setting:
CPU VID Control........................... - 1.27500V
CPU VID Special Add....................... - Auto
DRAM Voltage Control...................... - 2.270V
SB 1.05V Voltage.......................... - 1.07V
SB Core/CPU PLL Voltage................... - 1.55V
NB Core Voltage........................... - 1.53V
CPU VTT Voltage........................... - 1.20V
Vcore Droop Control....................... - Enabled
Clockgen Voltage Control.................. - 3.45V
GTL+ Buffers Strenght..................... - Strong
Host Slew Rate............................ - Weak
GTL REF Voltage Control................... - Disable
CPU GTL 1/3 REF Volt..................... - 110
CPU GTL 0/2 REF Volt..................... - 110
North Bridge GTL REF Volt................. - 110
DRAM Timing:
Enhance Data transmitting................. - Fast
Enhance Addressing........................ - Fast
T2 Dispatch............................... - Disabled
CAS Latency Time (tCL).................... - 5
RAS# to CAS# Delay (tRCD)................. - 5
RAS# Precharge (tRP)...................... - 5
Precharge delay (tRAS).................... - 15
All Precharge to ACT...................... - Auto
REF to ACT Delay (tRFC)................... - 35
Preformance LVL (Read delay).............. -8
MCH ODT Latencey.......................... -Auto
Write to PRE Delay (tWR).................. - Auto
Rank Write to Read (tWTR)................. -Auto
ACT to ACT Delay (tRRD)................... - Auto
Read to Write Delay (tRDWR)............... - Auto
Ranks Write to Write (tWRWR).............. - Auto
Ranks Read to Read (tRDRD)................ - Auto
Ranks Write to Read (tWRRD)............... - Auto
Read CAS# Precharge (tRTP)................ - Auto
All PRE to Refresh........................ - Auto
Clock Setting Fine Delay: default 70ps
Ch1 Clock Crossing Setting................ - Auto
DIMM 1 Clock fine delay................... - Current
DIMM 2 Clock fine delay................... - Current
Ch1 Command fine delay.................... - Current
Ch1 Control fine delay.................... - Current
Ch2 Clock Crossing Setting................ - Auto
DIMM 3 Clock fine delay................... - Current
DIMM 4 Clock fine delay................... - Current
Ch2 Command fine delay.................... - Current
Ch2 Control fine delay.................... - Current
Ch1Ch2 CommonClock Setting................ - Auto
Ch1 RDCAS GNT-Chip Delay.................. - Auto
Ch1 WRCAS GNT-Chip Delay.................. - Auto
Ch1 Command to CS Delay................... - Auto
Ch2 RDCAS GNT-Chip Delay.................. - Auto
Ch2 WRCAS GNT-Chip Delay.................. - Auto
Ch2 Command to CS Delay................... - Auto
Read delay phase adjust:
Channel 1 Phase 0 Pull-In................. - A
Channel 1 Phase 1 Pull-In................. - A
Channel 1 Phase 2 Pull-In................. - A
Channel 1 Phase 3 Pull-In................. - A
Channel 1 Phase 4 Pull-In................. - A
Channel 2 Phase 0 Pull-In................. - A
Channel 2 Phase 1 Pull-In................. - A
Channel 2 Phase 2 Pull-In................. - A
Channel 2 Phase 3 Pull-In................. - A
Channel 2 Phase 4 Pull-In................. - A
The site at edgeofstability is working again!
It shows the voltage measurement points. Yayyyyy :)
Surprised that those links weren't brought up on the 1st page of the thread... So here they are:
VDIMM measurement points
NB voltage, CPU VTT & CPU PLL measurement points
NB GTL & CPU GTL measurement points
ok,
now i have some stability whit vtt at 1,31v and vnb at 1,41v (cpu @ 3400 400 x 8,5); gtl settings at default (disable).
prime95 blend seems ok (2 hours test); vtt e vnb at stock give me error in few seconds.
prime95 small fft has rebooted my machine after about 30 min but i was testing the cpu whit a downvolt at 1,15v (cpu vid is 1,225) ... i was expecting a core error not a reboot
so now i'm testing whit default vcore and i have upped the vtt to 1,33v;
my ram (G.Skill PC2-6400 HZ Series) are set to 800 4-4-4-12 whit 2.0v and this is stock speed for these ram.
a little help please.according to the edgeofstability chart,if i set my vtt at 1.30 then i should start my fiddling at 89/90 for cpu and 89 for NB correct?if so why are everyone else's thet ive seen in the 60/70 range?say i set vtt at 1.30 and set the gtl's at 68/70/68,then how would i calculate what the % of vtt would be(Example 63% or 67% of vtt)im only asking cause it seems to be different from the asus P45 boards and the UD3P boards,calculating it that is.if i set it to disabled with vtt at 1.30 what does the board set the actual nimbers to and the %? sorry if im asking too much here but ive not been able to get a straight answer just links for charts and how to measure but thats not what im trying to find out.hopefully someone understands what im trying to ask.
