i would suggest looking at some of fatguy1999's posts.
http://www.xtremesystems.org/forums/...25#post3856625
he's done some amazing things with a Q6600 and phase and the UD3R
thanks so much!
Got the UD3R board, I am pretty new with it, but I have reached Q9550 @ 4300 Mhz that is Intel Burn Test ok. My question is what are safe voltages for 45nm Quads with these P45 boards? Do they overvolt or do other bad things with voltages? I have not checked with dimm anything jet.
So what is max for vCore, FSB voltage, also reference voltage, PLL, MCH. I have Q9550 with watercooling, under heavy load Intel burn test 66/66/65/65 max temps.
Can not compare this board with P35 Asus P5K-E, this one loves 500+ FSB with Quad :up: :clap:
With LLC enabled, voltage with a dmm is pretty close to what is set in bios for cpu. Cpu=z tends to read a little lower than the DMM usually.
For ddr I seem to get 2.1 when I set it at 2.06. So it is overvolted a bit.
And safe voltages.... I say 1.4v is as high as I am okay with volting the cpu under regular use. A few runs of spi or 3dm06 should be fine higher.
remember,these boards keep the cpu voltage the same under idle and load, so don't overdo it.
For me it is hard to get 518 FSB OK with Q9550, I did it, but with high FSB voltage, if I remember correctly, it was set to 1.48v in BIOS. What is this safe? I have read, that 1.51 killed a QX CPU, but it was different board :down:
Also I tried FSB reference up to 1.04v with no luck, that was when I reduced FSB voltage to 1.46v, I am aiming for 518 x 8.5, that gives me 4400 Mhz for 24/7, have not tested with 8.5 jet, just 8x, was OK with 4300 Mhz, for tests I use 25 loops of Intel Burn Test. I have also tested skew and it did bad if more than 0 is added for CPU, also 700mv for CPU is the best, 800 is also ok, but 900 or 1000mv is freezing.
Also, this is the same chip Q9550 L845B with 1.275v VID (looked badly first), that was on Asus P5K-E P35, no more than 450 FSB, even 455 had freezing problems, and Gigabyte UD3R board is great. Lets hope in can handle 8 Gb of DDR2 good too, P5K-E did it great, 8gigs at ~ 1100 5-5-5-15. :p:
Does any body here own GTA IV? If so do you get a stuttering with the game? I know it seems off subject but trust me it's not.
If i want to run SATA ports in AHCI mode i must enable both "Sata RAID/AHCI Mode" => AHCI Mode and "Onboard SATA/IDE Ctrl Mode" or just "Onboard SATA/IDE Ctrl Mode" => AHCI mode ? 2 HDD's, no RAID function.
I usually just select both but it seems to really only require the first one being set to ahci.
Is sleep function fixed in bios 10 beta series for ep45-ud3p ver 1.0?
Thank you sergio ! It wasn't anywhere near stable though, just a screeny.
i.e. your post in the q9650 thread, thanks for that as well :) ... i won't be scared to put 1.5v+ for MCH and VTT, as long as it is for short term benching...
I believe the first one is for hard drives only, ACHI is faster than the default. But be warned, for XP you will need to install the ACHI drivers during install...
The second i believe is for optical drives, correct me if i'm wrong? If i set it to ACHI it loads discs faster etc...
I have a bit of a problem that i need some help with.
Basically, i can boot 500x8 and run blend for a while (with 1.28vtt, 1.30mch), not tested for thorough stabilty yet, but it runs for a good half an hour or so before i stopped. But, i went back down and tried to make my way up from 485x8, and it seems i can't get it to even run more than 3 tests of blend :confused: I tried setting the exact same settings as 500x8 and it still doesn't pass 3 tests, i try more voltage and it makes it worse, i tried less and no difference. I messed with the amps, and skews and still can't pass more than 3 tests... :shrug:
I then gave up and tried going for 495x8.5 for a 24/7 clock (4.2ghz... 4.2 is 99% stable at 467x9 at the given vcore), but yet again, it doesn't pass more than 3 tests. I tried 500x8.5 with the same settings and it went on for 20mins :confused: but i blue screened, it doesn't make sense.
I can get 480x8 stable and 500x8 sort of stable, but 485 to 495fsb seems impossible to get stable...
Any thoughts?
the Onboard SATA/IDE Ctrl Mode one is for the two purple
sata ports if i remember correctly.the other is the ICH10
intel ports.
I am really having issues going over 450 FSB with E0 E8600 (Bios 10f)
The build: EP45-UD3P board + 2x2Gb Mushkin DDR2 1100 + E8600
All watercooled, CPU with his own loop.
The settings:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: [A]
CPU Clock Ratio ......................: [8X]
x Fine CPU Clock Ratio................: +0.0
CPU Frequency ........................: 3.60GHz( 450x8)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control................: [Enabled]
x CPU Host Frequency(Mhz).............: [500]
PCI Express Frequency(Mhz)............: [100]
C.I.A.2...............................: [Disabled]
>>>>> Advanced Clock Control..........: [Press Enter]
CPU Clock Drive.......................: [800mV]
PCI Express Clock Drive...............: [900mV]
CPU Clock Skew........................: [ 0ps]
MCH Clock Skew........................: [ 0ps]
******** DRAM Performance Control ********
Performance Enhance...................: [Standard]
Extreme Memory Profile(X.M.P.)........: [Disabled]
(G)MCH Frequency Latch................: 400
System Memory Multiplier (SPD)........: [2.00D]
Memory Frequency(Mhz).................: 900
DRAM Timing Selectable (SPD)..........: [Manual]
>>>>> Standard Timing Control
x CAS Latency Time................5...: [ 5]
x tRCD ...........................5...: [ 5]
x tRP.............................5...: [ 5]
x tRAS...........................18...: [15]
>>>>> Advanced Timing Control.........: [Press Enter]
x tRRD............................3...: [4]
x tWTR............................3...: [4]
x tWR.............................6...: [6]
x tRFC...........................52...: [58]
x tRTP............................3...: [4]
x Command Rate (CMD) .............0...: [ 2]
>>>>> Channel A Timing Settings.......: [Press Enter]
x Static tRead Value.............10...: [9] or [10]
x tRD Phase0 Adjustment...........0...: Auto
x tRD Phase1 Adjustment...........0...: Auto
x tRD Phase2 Adjustment ..........0...: Auto
x tRD Phase3 Adjustment...........0...: Auto
x Trd2rd(Different Rank)..........6...: Auto
x Twr2wr(Different Rank)..........6...: Auto
x Twr2rd(Different Rank)..........5...: Auto
x Trd2wr(Same/Diff Rank)..........8...: Auto
x DIMM1 Clock Skew Control (ps).......: Auto
x DIMM2 Clock Skew Control (ps).......: Auto
x DDR Write Training..................: Auto
>>>>> Channel A Driving Settings......: [Press Enter]
x Driving Strength Profile............: [1066MHz]
x Data Driving Pull-Up Level..........: Auto
x Cmd Driving Pull-Up level...........: Auto
x Ctrl Driving Pull-Up Level..........: Auto
x Clk Driving Pull-Up Level...........: Auto
x Data Driving Pull-Down Level........: Auto
x Cmd Driving Pull-Down level.........: Auto
x Ctrl Driving Pull-Down Level........: Auto
x Clk Driving Pull-Down Level.........: Auto
>>>>> Channel B Timing Settings.......: [Press Enter]
>>>>> Channel B Driving Settings......: [Press Enter]
****** Motherboard Voltage Control ******
Voltage Types..........Normal...........Current
>>> CPU
Load-Line Calibration.................: [Enabled]
CPU Vcore..............1.27500V.......: [1.45V] real [1.408]
CPU Termination........1.200V.........: [1.300V]
CPU PLL................1.500V.........: [1.59V]
CPU Reference..........0.760V.........: [.745]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.40V]
MCH Reference..........0.760V.........: [.72]
MCH/DRAM Reference.....0.900V.........: [1.05]
ICH I/O................1.500V.........: [1.5V]
ICH Core...............1.100V.........: [1.1V]
>>> DRAM
DRAM Voltage...........1.800V.........: [2.10V] memory is rated 1100 at 1.9V
DRAM Termination.......0.900V.........: [1.05]
Channel A Reference....0.900V.........: [1.05]
Channel B Reference....0.900V.........: [1.05]
Anything over that 455 x 8 is a no post. But as it is now is LINX 20 pass stable. CPU voltage can be much lower @ these settings will go with VID. Which is 1.250.
Memory is well capable of 1200 at 2.2V.
CPU can go 4.5 Ghz on MFII.
I tried all sorts of trial and error tests, read the forum etc. but i am stuck!
So what do you think? Could someone who knows his way with 2-cores give me some input? Thank you!
Read this thread,maybe will help you:
http://forums.tweaktown.com/f69/ga-e...-450fsb-31949/
very NICE chip :up:, with v1.35, my e84 only can touch 4.45 GH :down:
http://i34.tinypic.com/1gc4m.jpg
FOR FSB 525 ( 4.75 GH ) can do with v1.36, BUT only 4 Super PI 1 MB.......:D :up:
http://i34.tinypic.com/jgmz6e.jpg
VNB 1.38v, DDR2 1200 5/5/5/15 @ 1.9v
FSB 1200 cl 5/5/5/15 @ 1.90v
http://i33.tinypic.com/33ngcig.jpg
Gaul,thanks.looks like youve got a nice one too.
which board is that on?the UD3P?
Here is mine.
http://img32.imageshack.us/img32/1180/wootp.png
Robust Graphics Booster ..................: Auto
CPU Clock Ratio ..........................: 8
Fine CPU Clock Ratio......................: +0.5
CPU Frequency ............................: 4.00Ghz (500x8.5)
Clock Chip Control
CPU Host Clock Control....................: [Enabled]
CPU Host Frequency (Mhz) .................: 500
PCI Express Frequency (Mhz) ..............: 101
C.I.A. 2..................................: [Disabled]
CPU Clock Drive...........................: 1000mV
PCI Express Clock Drive...................: 1000mV
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 0ps
Performance Enhance......................: Turbo
MCH Frequency Latch......................: 333
System Memory Multiplier ................: 2.40D
Memory Frequency (Mhz) ..................: 1200
DRAM Timing Selectable ..................: Manual
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP......................................: 5
tRAS.....................................: 18
Advanced Timing Control [Press Enter]
tRRD.....................................: Auto
tWTR.....................................: Auto
tWR......................................: Auto
tRFC.....................................: Auto
tRTP.....................................: Auto
Command Rate (CMD) ......................: 2T
Channel A
Channel A Timings Settings
Static tRead Value......................: 8
Channel B
Channel B Timings Settings
Load-Line Calibration.....................: Enabled
CPU Vcore...............1.22500V..........: 1.3875~ under load 1.344
CPU Termination.........1.200V............: 1.44
CPU PLL.................1.500V............: 1.570v
CPU Reference...........0.760V............: 0.937
MCH/ICH
MCH Core................1.100V............: 1.50v
MCH Reference...........0.760V............: 0.912v
MCH/DRAM Reference......0.900V............: 0.96v
ICH I/O.................1.500V............: 1.500v
ICH Core................1.100V............: 1.200v
DRAM
DRAM Voltage............1.800V............: 2.0v
DRAM Termination........0.900V............: 0.86v
Channel A Address Vref..0.900V............: 0.86v
Channel B Address Vref..0.900V............: 0.86v
Advanced Settings
Limit CPUID Max. to 3.....................: Disabled
No-Execute Memory Protect.................: Disabled
CPU Enhanced Halt (C1E)...................: Disabled
C2/C2E State Support......................: Disabled
x C4/C4E State Support....................: Disabled
CPU Thermal Monitor 2(TM2) ...............: Disabled
CPU EIST Function.........................: Disabled
Virtualization Technology.................: Disabled
Ok I changed PLL to 1.5v
What's PL?
I'm also curious to know why CPU-Z reports Core Voltage at an almost constant 1.424v when I had it set to 1.39 (and just lowered it to 1.38, still no change)
Anything else I could lower?
Here are my settings on my board with a q6600 and a single stage, anything i should change or anything too high on volts? this is just my first play with overclocking on this board, hopefully i can get to 4.4 or 4.5ghz. What should i set me memory to? These new settings on this board confuse me a little.
The settings:
CPU Clock Ratio ......................: [9X]
CPU Frequency ........................: 4.05GHz( 450x9)
x CPU Host Frequency(Mhz).............: [450]
(G)MCH Frequency Latch................: 333
System Memory Multiplier (SPD)........: [2.00C]
Memory Frequency(Mhz).................: 1080
DRAM Timing Selectable (SPD)..........: [Auto]
>>> CPU
CPU Vcore..............1.27500V.......: [1.5]
CPU Termination........1.200V.........: [1.38]
CPU PLL................1.500V.........: [1.61]
CPU Reference..........0.760V.........: [.914]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.34]
MCH Reference..........0.760V.........: [.914]
MCH/DRAM Reference.....0.900V.........: default
ICH I/O................1.500V.........: [1.570V]
ICH Core...............1.100V.........: [1.200V]
>>> DRAM
DRAM Voltage...........1.800V.........: [2.18V]
Everything else auto or default
nvm
