Originally Posted by
Barbarosso
İntel e8500 and thermalright true black coller
bios 1702
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5 and 9.0 500*8.5=4250Mhz stability -500*9.0=4500Mhz dont stability
FSB Strap to North Bridge: 400
FSB Frequency: 500 -533
PCI-E Frequency: 100
DRAM Frequency: DDR2-1000
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Auto
1st Information : Auto
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information : 7-3-5-4-5-4-7
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information : 14-5-1-6-6
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Read Training: AUTO (Try Disabled)
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: Auto (This is on Manual Yes?)
C/P: A1 A2 A3 A4 | B1 B2 B3 B4
LVL: 10 10 10 10 | 10 10 10 10
CPU Voltage: 1,40 -1.46 (Kinda High)
CPU GTL Voltage Reference (0/2): 0,370 (?)
CPU GTL Voltage Reference (1/3): 0,470 (?)
CPU PLL Voltage: 2,00 -2.20 **(WAYYYY to High)**
FSB Termination Voltage: 1.40-1.55 500FSB-auto stability ,533FSB 1.42-.1.54 dont stability (Too High try way lower)
DRAM Voltage: auto ( Set to spec )
NB Voltage: 1.40 - 1.50 500FSB- Auto stability ,533 FSB =1.42v-1.50v dont stability (Unless active cooling 1.4v)
NB GTL Reference: AUTO
SBridge Voltage: auto
PCIE SATA Voltage: auto
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
CPU Margin Enhancement: PERFORMANCE
Advance CPU Settings
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: disabled
my chipset nice coller two 6 cm fan
my cpu coller thermalright true black 120 two 12cm fan cool
my case two right intake 12cm fan and there front 12cm fan
my cpu 1.41 4250Mhz Stability 65C
1.42 and 1.48 4500 Mhz dont stability what the problem bios settings.
what the 533FSB nb and FSB Termination Voltage ??
İntel E8500 Cpu 4500Mhz 1.40v-1.48v not stability my bios settings ,what bad ??
helping me please
soryy i speak english bad
