looking forward to getting mine soon...:clap:
test it now!!!!!
hehehe.. your all lucky guys.. I think I will have a look on the DFI p35 LP when all the X38 comes out.. :(
hehehe but I have a new toy here.. :D
good luck with the OC guys.. :) please report if there are vdroops.. thanks
Quad S Pi 32MB with no memory / cpu tweak & loose timing : 5-5-5-18
http://img250.imageshack.us/img250/7...pi32mb1vi7.jpg
Later will test with tight timing.
here's DFI LP UT P35-T2R with 8/10 bios
System
- Intel Core 2 Duo E6750 ES - L710A438 G0
- Scythe Infinity with modded mount + 120x25mm Spire 96cfm fan
- Transpiper heatsink NOT installed
- DFI LP UT P35-T2R 8/10 bios flashed from 7/27
- 128MB Gainward FX5200 PCI
- 2GB Corsair 10000C5D Dominator on Green dimm slots
- 80GB Hitachi 7K80 SATA
- LiteON CD-RW
- 700W OCZ GameXStream
- WinXP Pro SP2
http://fileshosts.com/intel/DFI/DFI_..._dfi_p35_1.png
http://fileshosts.com/intel/DFI/DFI_...superpi32m.png
anyone try this mobo with galaxy dxx psu they dont work together for me
I got mine last saturday and been playing with it all week. FSB450 X 8 @ 3.6GHz ended up being my 24/7 OC.
C2D E6750 2.66GHz GO @ 3.6GHz / 450FSB X8 / 1.35Vs (air)
AC Freezer 7 Pro
DFI LP UT P35-T2R
Gskill DDR2 800 HZs / 1:1 4-4-4-12 / 800MHz
Corsair HX 620W
Subscribed. Mine will get here early next week I hope :)
Just a quick note for everyone. DFI LP UT P35-T2R + AC Freezer 7 Pro = a good bit of modding. It can fit if your willing to do a bit of modding, but if not then dont go with that CPU HS.
http://img.photobucket.com/albums/v2...Picture045.jpg
http://img.photobucket.com/albums/v2...Picture046.jpg
It was the only CPU HS I had on hand short of the stock one and I did not mind chopping it up a bit cause they can be found for really cheap.
Wow eva2000 that nice work!!;)
I set the parameter in bios(channel 2 clock fine delay 13 instead 14/auto) and the ram go like p5k dlx....nice
Here 2 spi32M with identical O.S.
Last official bios
Teamgroup 9600
P5k dlx spi32M
http://news.tecnocomputer.it/stuff/F..._12_51_485.JPG
DFI P32 TR
http://news.tecnocomputer.it/stuff/F..._12_51_000.jpg
BIOS SETTING
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio:7
- Target CPU Clock:3605
CPU Clock:515
Boot Up Clock:auto
DRAM Speed:266/667
- Target DRAM Speed:1206
PCIE Clock: 110mhz
Voltage Settings
CPU VID Control:1.365
CPU VID Special Add:auto
DRAM Voltage Control:2.47
SB 1.05V Voltage:1.217
SB Core/CPU PLL Voltage:1.95
NB Core Voltage:1.74
CPU VTT Voltage:1.38
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.75v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
- Enhance Data transmitting: FAST
- Enhance Addressing: FAST
- Channel 1 CLK fine delay: CURRENT[14]
- Channel 2 CLK fine delay: 13
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD):4
RAS# Precharge (tRP):4
Precharge Delay (tRAS):12
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance Level: AUTO
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
The subtiming are setting with memset
It is really great mobo +600 with aircooling no problem ... but here in Europe is too expensive ... 266EUR or 372USD!
For that price is not too good buy ...
In Canada its $297. But not here for another 2 weeks :(.
Here in Czech rep. only ME have ONE, but in retail stores in 3 weeks!
Did anybody take SuperPi numbers compared to a 965 board at the same clocks?
can you provide bios version and settings you used for those clocks ?
27/07/07 Bios template:
Use this template to share your DFI UT P35-T2R bios settings :)
CPU Feature
CPU Clock Ratio:
- Target CPU Clock:
CPU Clock:
Boot Up Clock:
DRAM Speed:
PCIE Clock: 100mhz
Voltage Settings
CPU VID Control:
SB 1.05V Voltage:
NB Core Voltage:
CPU VTT Voltage:
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
DRAM Timing
- Enhance Data transmitting: AUTO
- Enhance Addressing: AUTO
- Channel 1 CLK fine delay: AUTO
- Channel 2 CLK fine delay: AUTO
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 6
Ranks Read to Read (tRDRD): 6
Ranks Write to Read (tWRRD): 5
where do you get 600+ with air cooling...that just not true?
Chilled 600 maybe, air 550ish to 570 tops with an exceptional CPU.
Highest here with X6800 527
Highest here with ES6850 475
Highest here with ES 6750 500
Spoke to DFI who had 480ish with ES6850 and 530 with retail 6850
chilling gets you FSB to 600, air does not.
I have not posted because I thought i was seeing a board issue as I was not able to reproduce the hyped 600 but in reality im seeing what normal end users will see and thats quite a bit less BUT that does not mean its slow.
http://www.ocztechnologyforum.com/st...1200at4GHZ.JPG
Sub 50ns dead easy with next to no tweaking, GTL voltage tweaks help with FSB EVEN on dual cores so there is a lot more to do.
thanks gandalfone for the settings :)
tony and gandalfone, have you tried 2:3 mem divider yet ?
Here 8800golds all auto set in bios at 1150, 6750@3.833GHZ
http://www.ocztechnologyforum.com/st...0_gold8800.PNG
Performance level 7 by auto ;) Oskar has doon a great job tweaking the board and in most cases Auto's are all you need :)
thanks for the results guys.. :) more please.. :)
:woot:
Really nice mobo and nice results guys ;)
Regards
got it today, it is out of the box a litte bit faster than my P35-DS4. But it do only
the same FSB as my P35-DS4 :( (CPU FSB wall)
3DMark06 with DFI LanParty P35
http://www.muenster.de/~e30pics/Bild...P35/DFI-01.jpg
3DMark06 with Gigabyte GA-P35-DS4
http://www.muenster.de/~e30pics/Bild...-P35/GB-01.jpg
AM³ with DFI LanParty P35
http://www.muenster.de/~e30pics/Bild...P35/DFI-02.jpg
AM³ with Gigabyte GA-P35-DS4
http://www.muenster.de/~e30pics/Bild...-P35/GB-02.jpg
Wow great info guys, thanks for posting all that up. This is giving me some ideas. I got some more testing to do as I cant get my E6750 over 3.6 and keep it stable.
heres what mine can do
http://i68.photobucket.com/albums/i5.../2900x1.5v.jpg
