Asus Maximus Formula - BIOS help please ....
Hi guys , before I read through 189 pages here I would like to present you with my problem and maybe someone can help .
Now that I have my new rig running I have started benching in ernest . I can hit 3200 MHz easily as you would expect but even 10 MHz over that and its very unstable so for now I am going to play with vid card clocks , but I really need to get on top of this . Shortly I will post all of the bios settings and see if anyone can shed some light on this for me . Another issue that has surfaced is that if I go into bios , save any settings then try to restart it wont start as per normal , the lights etc flash and it goes dark again. After this the first touch of the power button has a similar effect then next application results in a start up . This is eery and has me concerned. I am also concerned with nb/sb temps but I am yet to apply some proper airflow to that area so I will see how that goes after that mod.
BIOS version 0907
There are alot of settings I have not come across before , so I have alot to learn. I can hit 3200 with everything on auto (nub I know) only bit of extra cpu voltage , but everything I tried would not help stability even at 8x410 . This board is much more complicated than my P5K was , Im sure if I can master it then it will fly.
Any help would be greatly appreciated.
:up:
Edit: I tried the 8x450 settings in OP and no boot , Im still reading here guys and am trying some different things but it still disturbs me how many times I have to try to start it after entering bios before it starts up .
Should I start a new thread for help or leave this here ?
Edit2: I got it up to 3600 but it needed 1.5v to be stable enough to bench , have not tested long term yet . I assume that some of the advanced bios settings can improve stability while reducing raw cpu voltage , would this be right ? Its an L737B with 1.2125v VID so I had hoped for more.
