:rofl: lets play yeah :up:
Your reference voltages for CPU and MCH are off. try setting default vtt 1.20v and try .785 cpu ref and .80 mch ref, then raise vtt back up, leaving ref's alone. a bump up or down a notch can make a difference in stability. The other ref's leave auto until you get some stability at your desired oc, then learn them. You may need more mch. You will probably be able to lower vcore and vtt with the correct reference voltages.
If you take the time to look through this thread all the answers are here.
Downloaded RealTemp vs 3.0, cant find my VID.
Where in the picture the VID is located I have a time counter going up.
Correction.
VID is 1.25 at my clocks in my previous post, I do not know if my voltage modification has changed or if it is possible to change my VID.
I'm in now. Chip should be here Friday. I already have the ram (gskill9600 PI) but the board is an ud3R not a ud3P though. We'll see. I expect good things. I really want 4500 stable for daily use (under 1.4v in cpuz). it should be simple after dealing with this high vid chip.
I'm going to be adding another radiator in the process too. Right now I'm cooling my gtx285 with a koolance fc block inthe same loop as my pc on a dtek v2. I'll be adding a mcr220 to my current mcr320 for added cooling power.
I'll post pics of my new baby when she arrives.
I'm on vista 64, do you guys think I'd see better oc results from 7?
I preordered already for this machine, just waiting till release. My real issue with it is that I play bf2142 pretty frequently, and I've read it won't let punkbuster work properly with 7 (it sees it as non-retail o/s and kicks you a lot).
well was fun while i had it. Returned the board. S3 sleep wouldnt work no matter what setting i played with. Only would work bone stock @ 266 fsb.
for some that might not be a big deal, but borked sleep mode is a deal breaker for me. I wonder if i had a bunk board? Back on my P35 and everything stable and working good.
going to get a lynnfield set up
BIOS available today:
GA-EP45T-UD3P - F8c
GA-EP45-UD3P - F10f
Thanks.
Scared to flash mine from F9c...I got a corrupted BIOS and it reverted to the backup BIOS so I don't know how to get the other one working again, lost all my profiles :(
Lately my board has been hanging on cold boot too, takes a few hard resets sometimes to get it to get past the memory check, usually just stops after it recognized the CPU and sits all day long :shrug:
You might try backing the FSB down a little, and see if it continues or not. My P35 DQ6 deffinately had the same issue towards the end of me having it though no doubt about it. I was curious about the revision of your board based on your over clock though if you were wondering. I am just hoping this revision isn't crap compared to the 1.0 that is.
Heh guys...if i pass windows memtest (4instances) 200% does that mean my Vdimm, timings, MCH ref, MCH voltage is spot on?
Ok guys i tested this OC for an hour + on prime blend BIOS F10f...then decided to go back to F10B using Qflash...after restart SAME DAMN PROBLEM " BIOS RECOVERING AND F10e CAME BACK" I NEVER EVER HAVE THIS PROBLEMS BEFORE FLASHING F10e GIGABYTE PLEASE FIX this its an awesome board doesnt diserve this...
http://img4.imageshack.us/img4/6373/captura1r.png
Ok guys i flashed back to F10b and that OC that i can pass on F10f i cant pass it on F10b, it fails in seconds...so i think that they adjusted something, thats why latencies are lower...So only thing they must fix is have the original bios as backup and not F10e.
Cheers
Sergio
Nope mate, there a lot of users on other forums reporting the same i started to get that when installed F10e, and talked to stasio and its like that. If i leave F10e or F10f wich im on now nothings wrong...but somehow this bios allowed my to do fine on 8,5multi and a little more on mem divider 2,50A wich sucked badly needed lots of volts...
Thank you
Sergio
For me f10f allows stable work with 2.4D memory divider:
[img=http://img525.imageshack.us/img525/175/4gigi.th.jpg]
It's me or after some time voltage droop slightly increases ?
I had set prime95 running earlier today, I have just come to the PC and it is off. I turned it on via the power button and prime95 resumed from where it left off.
I have checked the BIOS and all power management features have been turned off, EIST etc.
Is this a Windows 7 issue or a BIOS setting?
