Nobody knows what that is, and it's not a C0 Stepping FX
Originally Posted by Google AcrossAfter
Since I was the one who found the BOINC report I want to add a bit to this discussion ;)
My original suggestion was C0 stepping. In the thread you translated (original here) one user assumed it to be a Vishera ES, which caused the corrective response by another user - the one you quoted. So indeed, the C0 stepping is no Vishera ES, since this would have a model number 20h-2fh.
Model 2 puts it clearly into BDver1 range (Orochi or OR-A0... steppings). As model 0 stepping x translated to OR-Ax steppings, and model 1 stepping y to OR-By steppings, I suppose model 2 stepping 0 simply means C0. The only thing missing is an official public document supporting this.
and how does it compare to older steppings? any visible difference?
None. BOINC scores are not exact enough to spot anything. C0 would not come with the changes which were planned for Piledriver, Steamroller, Excavator years ago (otherwise they wouldn't be able to deliver such updates in a one year cycle).
But it might have lower power consumption or reach higher clocks.
Something new about Vishera?
http://www.newegg.com/Product/Produc...82E16819106011
water cooled kits finally showing up...so much for at launch water cooled kits
I thought only Japan or somewhere had LC kits at launch...
Regardless, none of these are going to sell. I don't know what AMD is thinking.
be kewl if they sold the water cooled unit separately, they revised the mounting bracket to be much better (than the stock antec khuler 920)
I just wonder if there was any binning on the chips for these sets (to match water)...
It'll be interesting to see some results.
Provided anyone on here buys them OFC... :p:
Dave: I have one setup home...But I need some new CPU chip :(....
why are they show 3.9ghz? Are these different....
"AMD FX-8150 Zambezi 3.9GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor with Liquid Cooling Kit FD8150FRGUWOX"
Edit: Missed your post Beep..
"AMD FX-8150 Price Drops Like a Rock"
Source: Techpowerup
anybody remove the IHS on bulldozer yet? Or is it soldered on?
must be soldered! I have 2 dead cpu w/o warranty so i can try to remove the IHS to see how it is :p
IHS remove is some years dangerous...Thubans deaths after this, all Intell chips too of course. And FX will be not different Im thinking
The chips die because of wrong methods of removal, improper cooling or physical damage to the die or package, the missing IHS has nothing to do with it directly.
Even if you manage to remove the IHS without any physical damage and even cool it down properly, the chip might still die within 1-xxx days without any obvious reason. In this case the actual "cause of death" lies in the botched methods of removal:
Thermal shock - The chip was heated or cooled down too quickly during the IHS removal process, which caused damage to the silicon or silicon-substrate interconnects / bonding.
Mechanical stress - Excessive force was used on the IHS before the "TBC" had reached the melting point.
This caused damage to silicon-substrate interconnects / bonding.
The usual TBC (48% indium, 52% tin) used to bond the core to the IHS has liquefying point at ~120c.
This is nowhere near the temperature the chip can temporarily withstand in non-operating state.
According to Intel, the maximum short-term (>72h) STORAGING temperature for their chips is 125c.
So if you know exactly what you are doing, removing the IHS is quite safe.
Worth all the work and trouble nursing the fragile core and making custom cooler mountings for the now non-standard (height) chip?
:D
I know what he said.
Lets assume the contact between the thermal interfaces are 100% in each case:
Heat transfer path:
CPU with IHS: Die -> IHS -> Cooling element
CPU without IHS: Die -> Cooling element
Without the IHS there is one thermal interface less in the path, which means the heat transfer is quicker and due real world manufacturing tolerances (IHS surfaces, cooling element surface) more efficient.
I have removed "soldered" heatspreaders successfully from countless chips since the "soldering" method was introduced (IIRC in around 2003, P4 Gallatin). I never lost a single cpu because of IHS removal and I bet they all still work unless they have been scrapped. Still might have some of these P4īs, C2Ds and Phenoms II in my archives.
I was just asking if you had any explanation as to why he found what he did...
"Thermal shock - The chip was heated or cooled down too quickly during the IHS removal process, which caused damage to the silicon or silicon-substrate interconnects / bonding."
Or
"Mechanical stress - Excessive force was used on the IHS before the "TBC" had reached the melting point.
This caused damage to silicon-substrate interconnects / bonding."
Or
"Hotspotting" due bad contact between the die and the cooling element.
This is highly unlikely because silicon has quite good thermal conductivity properties.
Chip getting damaged this way would require VERY poor contact.
Also I am quite certain chew can install the cooling properly, so this is not the case.
Do u have some free FX for IHS remove?
FX-8170??? True or not?
Such a significant difference between official price and actual price may indicate that AMD has quietly reduced the price of the FX-8150 model in the light of Intel's latest product launch as well as to clear the road for the new model FX-8170, which should become available in Q2 2012.
http://www.xbitlabs.com/news/cpu/dis...hip_Chips.html
If true, i would be really pissed cause i just recently bought the FX-8150 and all this time i was waiting for the FX-8170!!
