WOOOOT, OH HOT DAM!!!. Looks like we cross posted AHAHAHAHA.
Crossing ma fingers for the big read. Wait 70 seconds? NOOOOOOO
13 minutes late...you're gonna stick me on 13 minutes.?
first the short and skinnee joke now 13 minutes, jeez.
:rofl:
Thanks for the review skinnee, good read. Any plans to do testing of dual loops with a Y coming off the other tops going back into a res with dual inlets as a base of comparison? Just seems like a more realistic comparison and better way to see what advantage the T3 really provides. Comparing dual loops against single loop is kind of like tying one hand behind your back in a boxing match :D
Did you notice any temp difference using the T3 with dual loops versus the other tops with single loop?
I thought this at work today, and we discussed it earlier in this thread...its not needed, but I will run some just to prove out Vapor's math. But I am moving my lab to a new room this week, earliest I can get to it is maybe this weekend.
I didn't run any thermals, that would've taken weeks longer.
Actually...if you're curious still, you should go back and reread some of the posts in this thread...Vapor explained the math. Running those tests will only take more time away from testing other blocks/pump/rads etc, to put a chart to the facts already discussed.
I'm not saying that to be rude, just my tail is getting to big of a backlog...and thats not good if we want to continue to see more reviews from skinnee labs.
Skinnee, thanks for spending SO much time with the T3. No doubt at all that Martin made the right choice for his successor.
Blue Haze; Does that mean I get to add Y's to each of the T3 loops for a little Quad loop love? Obviously the Typhoon III has the flow power to pull it off :D
And just in case you guys missed the video cause the page switched:
http://geno.boxgods.com/MVI_0358.divx
Again, Thanks a lot for the great review Skinnee.
:up:, my pleasure!
[Review] Typhoon III (forum version)
Or a laser and a tapping arm. :)
First cut a hole through the top of the T3 large enough to recess the top of the plug.
I then added a 1/4" thick acrylic circle inside with a 29/64" hole, bonded to the inside of the reservoir (obviously the 2 holes need to be aligned concentrically) then tapped.
Looks like its a hot product.
Primochill site OOS for all 3 models.
Darn it.... most resellers OOS already....
No, I read it all that is why I am curious, Vapor posted his math then Boxgods disagreed with it so I don't think any conclusion has actually been drawn nor can it be until we have a comparison vs another top running two loops. As it stands it seems you would get similiar performance via adding a Y to the outlet of the pump and having each loop dump back into individual ports on the res.
Nevertheless I don't want to beat the horse here so if you don't have time to do the testing I will drop it. I am sure someone will be curious enough to do it eventually. I don't have a d5 or I would try it. Maybe I will try it with my ddc and see what happens, just have to pickup another flowmeter.
Anyways thanks again mate!
AH, I was not disagreeing with his math, was this part "EDIT: BoxGods' PEC explanation is the true way to look at it" and I was referring to his original statement being the easiest to UNDERSTAND. He has a way of explaining complex concepts in really easy to understand terms.
His math is actually more accurate then the formula I used.
When he used the Term "Through the pump" that really is an excellent way of explaining how a T3 does dual loops compared to placing a Y before and after a pump. Certainly easier for most to understand then the math formula.
I DO see where it looked like I was not agreeing whith his math the way I wrote my post though.
Well I have to say I really enjoy discussing this with you, it is refreshing to be able to have a civil discussion over the internet with discerning points of view as opposed to the typical flamewars that usually end up taking place. Much respect to you and Primochill as well for that, you guys seem like a really great company.
When you say "Through the pump" doesn't the pump still have one inlet and one outlet? It's not really possible to have a Y "in the pump" it either has to be before or after. Obviously having a Y both before and after is going to net you nothing because you end with the same restriction you began with. The advantage seems to come in from having the res at the end of the loop and having both the loops then dump back into the res without going through another Y. Thus allowing the res to act as an expansion chamber of sorts giving free flow to each loop individually without the restriction at the end.
Yes and no. If you look at the helix (or spiral involute if you prefer lol) in the T3 it is MUCH deeper then a normal D5 Top. Almost double. Because I could not make it any wider (again the D5's impeller dictates the with of the waters path) I pretty much cheated and made it deeper so that I could DOUBLE that primary outlet and get a lot more water into the PEC. The PEC regulates the pressure as close to the pump head as I could get it so there is not a huge pressure loss.
The rest Skinnee covers pretty well in his article. basically the portion of the loop that is actually inside your pump is doubled. If you do the Y method on a regular pump top, the entire loop (loops) may be doubled, but the section through the pump is still the single, or same flow as before.
Think of it like this. Obviously there is no Y inside the pump, but the single line that there is in there is the same volume (or close to it) as 2 lines would be. So when the dual loops of the T3 come together and pass through the pump, the volume of that section is still near the volume of 2 lines or loops. In the Y method on a regular top that line is just one lines worth of volume. Thats the restriction Vapor is talking about, not the restriction from the Y fitting itself, but the base leg of that Y "section", or the length of you loop that runs through the pump.
And yeah, I love talking about this stuff too lol.
So you are saying the size of the chamber coming off the pump makes the difference? Because the hanging point for me which we discussed before was that the water will take the least path of resistance. So in a free flowing loop the chamber would aid the flow by allowing more water to be fed through each loop with the pump being the only restriction, with that I agree.
However once you add restriction to the loop that is now the governing factor of your flow. Therefore as long as the flow coming through the Y was greater than the restriction through each loop you wouldn't even need a chamber because the water will fill each loop until equilibrium is reached.
In otherwords, just throwing numbers out there, if you have a pump able to flow 5gpm and a Y able to flow 4gpm, now run two loops off that y each with a restriction no greater than 2gpm and both loops dump back into a res removing the restriction at the end of the loop, you will have 4gpm flowing "through the pump" with no chamber at all on the outlet (open loop) because the Y is the restriction.
Now introduce a restriction greater than the Y to each loop and say you have two loops each restricted to 1.5gpm so the max you can possibly flow through these loops is 3gpm and you throw them on the pump flowing 5gpm through the Y flowing 4gpm. In this case your pump can flow 5gpm your Y can flow 4gpm so the governing restriction is the dual loops that flow 3gpm combined. Your flow rate is now determined by the restriction of the indivdual loops not by the Y, nor the pump, nor by any chamber in between the individual loops and the pump correct?
In otherwords your pump can still flow the full 5gpm because there is no restriction at the end of each individual loop, it's getting fluid from the res so is capable of starting each pass through the loop fresh with the full 5gpm capablity.
Is there something wrong with this train of thought?
Hey BoxGods Quick question when these products will be avail on the market & where thx ?
http://geno.boxgods.com/FM1opt.jpg
http://geno.boxgods.com/TC4opt.jpg
http://geno.boxgods.com/YC1b.jpg
Your going to have to loop up with the Y's and see for yourself because I cant think of any other way to explain it. The D5 produces XXX amount of power. To move the same volume of water through a smaller pipe at the same speed requires more power. If more power isn't available, go with a bigger pipe...the "pipe through the T3 is B I G G E R lol.
When they say the Y is the restriction, they mean the section of the Y's through the pump itself.
