Also, Shanghai (the 45nm successor for Barcelona) still has the same L2 cache size, while the L3 cache is expanded to 6MB.
Because of this, it seems that the AMD engineers didn't think the size of the L2 cache in K10 was going to limit it's performance, otherwise they would have addressed it in Shanghai.
The problem here is die size ; even if they wanted they couldn't put more cache on the 65nm version.At 283mm^2 it looks to be beyond what AMD's FAB can muster , at least for now.Yields are probably very poor , there is a lot of device variation which prevents them for shipping stable higher clocked parts.
Submitted by: Sang U. Kim, Ph.D (kimsang@wbhsi.com)
8/1/2007 2:29:13 PM PT
Occupation: retired, but active tehcnically
One of the major differences between the SOI and Bulk technology for the 45nm and beyond is to control the electostics or the short channel effects. For the bulk technology used by Intel the quantum confinement of carriers is controled by a combination of Hallow source/drain implant, and retrograded channel/substrate doping. On the other hand, for the SOI technology the quantum confinement of carries in inversion layer is carried out by physically reducing the SOI thickness, Tsoi by narrowing the space between the gate oxide and the buried oxide. To mitigate the short channel effects, 45nm SOI may require 50nm~40nm Tsoi, 30nm~20nm Tsoi for 32nm, and 10nm or less Tsoi for 22nm technology. Such a thin Tsoi causes significant carrier mobility degradation and increase in threshold voltage, Vt. Furthermore, for the scaled devices, the strain induced mobility enhancement techniques become less effective. This is particularly more so for the thin SOI technology simply because in such a thin ~10nm junction and isolation depths, and channel inversion layer thickness it is extremely difficult to implement GeSi S/D junctions and a large lattice mismatch induced by the relaxed Ge-Si substrate in the channel.
Even for the 45nm SOI technology, the manufacturability of the strain induced mobility enhancement techniques used for 90nm and 65nm may not be feasible. In this respect, the SOI technology for the 45nm and beyond has a significant disadvantage over the bulk technology. IBM and AMD are at the crossroad today to determine extenderability as well as manufacturability of the SOI technology for 45nm and beyond. The conversion from the SOI to the bulk 45nm technology node has enormous technological and manufacturability challenges. This is because IBM and AMD do not have the required learning experiences such as process, design, reliability and device yield gained from the 90nm and 65nm bulk technology development and mannufacturing. Furthermore, two major new materials were introduced in the bulk 45nm technology: the thermal oxide, SiO2 that was used for 40 years is replaced by HfO2, and the polysilicon gate that was used for over 30 years is replaced by the metal gate.
Today Intel is the only company that is manufacturing the bulk 45nm. If that is true, Intel has enormous advantages over its competitors, particularly if IBM and AMD have to adopt the 45nm bulk technology. This is because Intel must have resolved most of the device, process, reliability, and manufacturability issues as a result of introduction of the new materials and processes. When the new materials and processes like HfO2, metal gate, and their new processes are introduced, new or unknown faiure mechanisms will be also introduced. Therefore, it is crucial to design test structures so as to bring out the unknown failure mechanisms for early detection, and develop effective E-test and reliability test screens. Such experiences gained through the 90nm and 65nm bulk technology development cycles will give an edge to Intel in successful development of the 45nm technology and beyond.
