K Lar mate finished the tests (sorry for the delay) but it took at least an hour per setting and it was mainly an after midnite job :rolleyes:
First I booted the mobo with 0803 bios and used these settings :
1.94 (test 1) and 2.04 VDimm set (test2) , Vcore adjusted according bios
E8600 with 10 x 450FSB/1081Mhz -- 4GB PC8000 Mushkin Redline/4Gb Gskill PC8000PQ 5-5-5-15-55
WinXP Pro 32bit
CPU GTL Voltage Reference (0/2): 0.640
CPU GTL Voltage Reference (1/3): 0.640
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.24
NB Voltage: 1.26
NB GTL Reference: 0.630
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
On 0803 both Dimm voltage settings passed linpack test (repeated 3 times with a 10 test run) without altering any other setting then Vdimm :
1.94 Vdimm :
http://users.telenet.be/OAP/P5QDlx/biglar1.JPG
2.04 Vdimm
http://users.telenet.be/OAP/P5QDlx/biglar2.JPG
Then I reflashed back to 1406 (knowing I need a tiny bit more Vcore there)
1.94 Vdimm and CPU 1.381Vcore set
http://users.telenet.be/OAP/P5QDlx/biglar3.JPG
2.04 Vdimm and 1.381 Vcore failed 1-2 itenerations each time :confused:, rebooted reran 1.94 Vdimm, passed..Tried other rams... passes... upped Vdimm : failed bummer...
Started messing with the all the voltages but only a bit more Vcore helped me to pas the Linpack test 3 times in a row with zero failures...(for each ram set) I'm really puzzled here... will try the same on the other deluxe this week.
So to pass with 2.04Vdimm on 1406 I needed to up the Vcore to 1.387 (not 1.386 as in the piccie, that's a typo)
http://users.telenet.be/OAP/P5QDlx/biglar4.JPG
Hope it helps or maybe confuses you even more :(
