Originally Posted by
N.I.C
Nope, i haven't tried with higher Uncore yet (Dram Freq*2) , i cannot see how this suppose to help, but i'll give it a shot.
I have already tried with lower PLL (from 1.5 to 1.7) and i get the same results. With 1.85, was the best i could do on LinX/OCCT Linpack as i mentioned on my last post.
As i remember from my old s775 platform, the skews did help in many cases, but here from what i read, you can face exactly the opposite (much instabillity) using high ioh/cpu skews. I think that it's too early (low bclk, just 206, i see that achieving this bclk is piece of cake on W3520/decent 920) to start messing with skews, but i guess i'll have to start with it.
Another think i need to ask is about the LLC. on 0% calibration, i get much vdroop. To be exact, from 1.3750@BIOS (1.360@real/idle, measured with polymeter) it goes around 1.308@full load. Is that normal? On the other hand, with full calibration, it overvolts quite a bit (1.3750@BIOS-1.381@real/idle-1.383@full load), which, from what i've read, its normal.
50% Calbration is trying to keep the balance between the other two, but i get a lot of spikes on vcore some times.
What you guys use on LLC? full or 50%?
