thank you for the replay; do you have the mushkin? can you post some screens of them? Thank you :)
I don't have that particular kit, I have G.Skill 3x2GB DDR3 1600 8-8-8-21-2T, but from what I have read, that mushkin is some of the best, good OC headroom and fantastic timings.
For P6T 0403 Bios Up. 21x Multiplier doesn't work I'm afraid.
This sucks.
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...-ASUS-0403.zip
For P6T Deluxe V2 bios 0302 21x fixed multiplier doesn't work:shakes:
ftp://ftp.asus.com.tw/pub/asus/mb/LG...XE-V2-0302.zip
I'm currently doing a 20 LinX pass at these settings:
i7 920 Batch #3836B
Multi = 21x
BCLK = 191
vCore(Bios) = 1.42
vCore(Idle) = 1.15 (Clocks down)
vCore(Load) = 1.416 - 1.424
QPI = 1.35
IOH = Auto
ICH = Auto
DRAM = Auto
Max memory and Max problem size LinX gives me a top temp of 87c on the first core. Is this to high?
It seems my chip won't accept a 19x multi, and even then it's very unstable and crashes when i launch Prime95.
This is my first OC ever, anyone got any tips?
Cheers.
Dump the Tuniq!
I have first hand experience with it on a qx6700. Check this out:
http://www.xtremesystems.org/forums/...00#post2089917
I don't understand :confused: I was p95 stable @3.8 w/1.24v with bios 1102 update to 1303 for 21x multi, found that didn't work for me was not stable..... even p95 would fail at my oc of 3.8 w/1.24v so I reverted back to 1102 and now suddenly that is not stable with my old settings :mad: even tried 1206 with no avail WTF. Any ideas on why or what's going on? Chip degradation already........
I thought mine was degrading until I found out it was heat preventing me from using previously working settings.
With the Zalman 9700 I am using p95 blend temps didn't exceed 77-78 right I'm looking over and seeing temps of 74-75
The 21x mult8iplaier is great.....the last 3003 bios is great :)
http://www.pctunerup.com/up/results/...26_Cattura.JPG
Whats the major diferences from the P6T Deluxe to the normal P6T?
Question: Should these settings be Enabled/Disabled?
Advance CPU Settings
CPU Ratio Setting: 19
C1E Suppport: Disabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
Intel® Virtualization Tech: Enabled
CPU TM Function: Disabled
Execute Disable Bit: Enabled
Intel (R) HT Techology: Enabled
Active Processor Cores: All
A20M: Disabled
Intel (R) SpeedStep (TM) Tech: Disabled
Intel (R) C-STATE Tech: Disabled
mmz guy can someone please get on a the rails and link/tell me what bios options etc i best should disable?
Do you guys recommend that I first find the max bclck?
does those settings applie to me to ToMeGuN?
I'm new to oc'ing and I have a P6T Deluxe.
btw I was wondering since the 1303 bios you can go up to 21 with your cpu ratio.
Now intel said the 920 and 940 where locked to a bigger value but unlocked to a lower value.
Setting the cpu to 21 won't this permanently damage the cpu?
And by doing this the turbo feature doesn't work anymore right?
