Awesome :up: only 2.6v :shocked:
Keep pushing it :)
Keep pushing it :)
Thats "only" 690.405 MHz :).
Remember, the 3:5 is 2:3 reali.. so 1.5 x FSB is the real memory MHz..
M3kk
I want to look at the basis of this formula: 3:5 is 2:3 reali.. so 1.5 x FSB is the real memory MHz.., actually it can 1400 +
Here, too, is wrong?
http://s45.radikal.ru/i108/0811/4b/344b92ef1492t.jpg
OMG 678MHz w/ only 2.1v :shocked: for 2x2GB.
M3kk
It is a pity that so :(
AFAIK just the 3:5 is bugged, the 5:8 is ok, isnt it?
Here: http://www.xtremesystems.org/forums/...d.php?t=208542 you can read about it too, but exactly dont know where :).
The only bugged divider I has seen untill now is 3:5. :)
http://valid.x86-secret.com/show_oc.php?id=449103
Cellshock 8500 CL5 D9GMH
754MHz 2.74 Volts real
in the waterplate of my dog there was ICE in plastic package
air temp -5 and ice was cooled at about -8
it had no condensation and i could nearly achieve 800MHz
only so i could go above 760Mhz but with 3.05 volts
i will not validate some result
we had war in georgia for the first place of ddr2 clock and i am waiting for his answer :D
http://www.pic-upload.de/thumb/21.11.08/v41qgc.jpg
for the G.Skill 8500 HK's at 3:5 DDR2-1500 the voltage setting on EP45-UD3R (F3 BIOS) was same as this one below (see voltage setting in Easytune 6),
but was using different CPU multi and Vcore, also for the G.Skill kit I had to use more vdimm and the memory timing was using XMP profile 1 in BIOS (5-5-5-15 / 15(tRRD)-6-13-60-6).
http://img243.imageshack.us/img243/3...ton450xfz0.png
G.SKILL F2-9600 CL5D-4GBPI does not cease to amaze
New WR for 2х2Gb :)
1545MHz 5-5-5-15 2.6v dryice
http://s57.radikal.ru/i157/0812/9a/780207b21e39t.jpg
http://valid.canardpc.com/show_oc.php?id=468849
Good job, Highgertz.
Is there a list or is it just post by post....
thanks/steve
That is not the Wr there is a couple of people there have achived 1600+ mhz ddr2 speed look at the gigabyte competition
WaterFlex
You have too beautiful result :up:
systemviper
The tests will, I hope this is not the last dispersal.
Riska
A careful here 2х2GB.
I need a DDR2: 800Mhz Club ;)
http://img267.imageshack.us/img267/8...gigaqd7.th.jpg
This result with air @ Delta.
Ouuu Yeahh, Merry christmas!
