E1200 Dual Core Celeron 1.60Ghz @ 3.00Ghz
Hey everybody,
I overclocked my E1200 Dual Core Celeron 1.60Ghz @3.00Ghz these BIOS settings. Also, I tried to oc with @2.50ghz, @2.80Ghz, @3.20Ghz and I was successful with these speeds at that time too (I was use different settings for only @3.20Ghz). However, I tried to different BIOS setting variations for @3.40Ghz and then I was failure at that time. I couldnt reach @3.40Ghz at that time. Anyway, I can use it daily with @3.00Ghz and @3.20Ghz todays.
Everyone can give some advise for reach @3.40Ghz lol :)
BTW, I didnt add my screenshots or my valid values for cpuz yet but if u wanna them all, I can share for u of course.
Here we goes,
Code:
377FSB Dual Core Celeron BIOS Settings (907)
CPU Feature
Ai Overclock Tuner [Manual]
CPU Ratio Control [Manual]
Ratio CMOS Setting: [8]
FSB Frequency [377]
FSB Strap to North Bridge [Auto]
PCIE Frequency [100]
DRAM Settings
DRAM Frequency [Auto]
DRAM Command Rate [Auto]
DRAM Timing Control [Auto]
DRAM Static Read Control [Disabled]
Ai Clock Twister [Strong]
Transaction Booster [Enabled]
Boost Level [0]
Voltage Settings
CPU Voltage [Auto]
CPU PLL Voltage [Auto]
North Bridge Voltage [Auto]
DRAM Voltage [Auto]
FSB Termination Voltage [Auto]
South Bridge Voltage [Auto]
Loadline Calibration [Enabled]
CPU GTL Reference [0.63x]
North Bridge GTL Reference [0.67x]
DDR2 Channel A REF Voltage [Auto]
DDR2 Channel B REF Voltage [Auto]
DDR2 Controller REF Voltage [DDR2_REF]
SB 1.5V Voltage [Auto]
Note: English is not my first language... So sometimes I am not able to express myself properly... When I writes something in English, I can mix my own grammar in it so sometimes it sounds a little different to you. Really sorry but that
System Specs
Temperatures: 10 C between 23 C normal
Ram: OCZ Reaper 2Gb 800 Mhz Cl4 Kit (2x1gb) (With Heat Pipe Cooling)
Processor: Intel Celeron Dual Core E1200, 1.60 Ghz, LGA775 512k L2 Cache 800Mhz FSB - Cooling: Zalman Reserator XT
Motherboard: Asus Maximus Formula - x38+ICH9R - Rev1.xx
Graphics Card: GeForce 8600 GT - 256Mb 128bit GDDR3 - GPU Clock 540Mhz - RAMDAC 400Mhz
Hard Drives: 80Gb Maxtor, 160Gb Seagate, 320Gb Samsung
POWER SUPPLY: CM Real Power Pro 620w
Case: CM Stacker 831 Black
E8400 O'Ced @ 4.2ghz Vcore 1.60?
I've came to the conclusion this set up with Dual prime95 4 hours @ 4.2 ghz vcore 1.60:down: , ilde 24c, load 63c. NB @ 1.65v load 40c, SB @ 1.20v 31c. The problem is that I cannot lower the vcore @1.60 in order to stable dual prime95. The vcore is way too much! It should be at vcore 1.45v and temps are too high with the Coolit Freezone...It must be the PSU Enermax Liberty 620 Dual rail @ 36amps lack of AMPS? My goals is to reach 4.7 ghz:) I think the PSU is holding it back!
