Any tips on what voltages to use on ICH, IOH, QPI VTT for 24\7 on 4-4.4GHz
And does anyone know why the TURBO cuts off when going past 235bclk?
^ @ PlatoonSgtElias
regarding ur sig....
are u using 700W Seasonic M12 Modular for all that ? .........
then some PICS PL................
Whats so special about that? The PC takes just over 370w full load, with 2x295 it took little over 575W-s in full load. Idles around 230w.
meh heres some pics:
http://www.upload.ee/thumb/316581/P1090275.jpghttp://www.upload.ee/thumb/316582/P1090225.jpg
http://www.upload.ee/thumb/316584/P1090158.jpghttp://www.upload.ee/thumb/316583/P1090135.jpghttp://www.upload.ee/thumb/316585/P1090133.jpg
Anyway, im still searching what is the problem that TURBO drops off after 235bclk :(
^ Are u sure?
It just takes only 370w @ full load only if u run them @ default clocks ....
If not Buddy ur calculations are wrong ,Bcoz my system(u can see my sig.)
It takes about 300w idle & 500w full load.......
Measured ur wattage with any instrument or ur own calculation ....
No offense :)
anyway nice rig man ,nice & clean :D
Measured with a wattmeter!
Anyway, I got a Giga Extreme today, gonna get this mobo modded too, see if this one works better then the UD5
So we can get more juice from a low watt PSU instead of buying a high watt PSU ...........
@ PlatoonSgtElias
Ok if u Measured with a wattmeter! ,No prob ...
Myself just being curious ........
:up: for extreme .......
@ bex
regarding ur sig......
so many bench's & #1 UK Female OCer too.
thats what's called Beauty with Intelligence......................:)
Everybody has there spl. interests ....
I dont think what boys can do girls cant,it solely depends on there interest............
lmao@ people with ridiculously high watt consumption.
Buy a REAL energy meter. most of them are totally inaccurate.
Most of the cheap kill o watt meters publish an accuracy of within 1% or better. I can plug mine up to a 200 Watt lamp, with 200W bulb and kow meter reads 197W. Same for several other appliances of known wattage, all register within 1-2% accuracy.
Here is someone who did an independent review of cheap $20 kow meter, again found accuracy within 1% comparing to known wattages.
http://www.safehomeproducts.com/shp2...ter_Report.pdf
Here is another from Johnny guru forum using cheap kow meter compared to Valhalla Scientific 2101 Digital Power Analyzer (~$650 and supposed accuracy to .2%), again cheap kow meter tested accuracy ranged from 0 to 3%.
Sure they are not acceptable for the power company in terms of accuracy, but if my kow meter says I am pulling 650W from wall, it isnt going to be more than 10-20W off.
But since I am not planning on using this info to dispute the power company bills, I can accept 1-3% error. Even 10% error, which never have seen would still mean at 650W, not more than 65W off.
When you say these are so inaccurate, what percentage, and where are you getting your information? Can I see the study, which kow meter, when it was done?
1. I'm NOT the #1 UK Female OC'er officially... hence the "?"
2. You'd be suprised the comments I get for turning up at LAN and then pwning people at COD4 :rofl:
3. The number of jaws been broken and second even third looks I get when I give OC'ing input suggestions
4. I have neither? Just look at my avatar for crying out loud - a drunken Scot :rofl:
~Bex
PS. I just ran out of power! *Face palm* GOD DAMNIT STUPID BROKEN 850W PSU! WANT TO GET 4.7GHZ!!!!
^^^ Ok gr8 ,but u can be !
& best of luck 4 ur future ..............
@ rge & mudkip
those are not kill o watt ,those are hole in pocket for watt
650$ man ,those pricey one .............
I check with my ups which handles all my load ..I have one ups for my LCD & one for my CPU ...there are some LED's which show how much i consume ...... that's all
Is there any way i can check my wattage through voltmeter ..........
Well iv been hitting a wall trying to get much over 4.2Ghz. As my CPU will do 4.2Ghz LinX stable with 1.23v i was thinking i must have a bad mobo that just couldnt handle the BLCK. Today though i decided to stick most to auto and have ago finding max BLCK. It turns out it must be my bad clocks and not the hardware or my CPU just needs a massive jump in voltage to raise its speed much over 4.2Ghz. I was surprised by the amount of QPI/Vtt and vcore it needed to run at this BLCK.
http://i552.photobucket.com/albums/j...PU-ZScreen.jpg
http://i552.photobucket.com/albums/j...BLCKscreen.jpg
Hopefully now i know its capable of 221BLCK that I can get to 4.5Ghz 24/7
I hate my i7 920/EX58-UD5 setup, it can't even do 200 BLCK, stuck at 191*21.
Today i redit all my tests with the latest F9M Bios.
And i have isolated the problem. What i did:
Flashed the bios in dos with the autoexec.bat. Loaded optimal settings. Left everything stock. System booted:
Then set Uncore Multi 20x = System boots (default)
Then set Uncore Multi 19x = System fails and resets bios
Then set Uncore Multi 18x = System fails and resets bios
Then set Uncore Multi 17x = System fails and resets bios (i used 24/7 on the F7 bios)
Then set Uncore Multi 16x = System fails and resets bios
Then set Uncore Multi 21x = System boots
Then set Uncore Multi 22x = System boots
So it seems everything below stock is locked. And everything above works fine. But i'm running 195 QPI so with 20x muli my Uncore would be 3.9 GHz and i cant get that stable.
I have this problem with all BIOS version from F8 and higher. F6 and F7 work fine.
Is there anyone that has the same problem ? or am i the only one ?
Stock Uncore multi is 16x.
Are you sure you mean Uncore?
IS TB broken in latest BIOS (not BETA). Doesn't seem to work for me... temps have went mega wierd even with a bad mount... Idles ~45c but load her up and she crys...
But.... I had some lol's today... Not the best but hey - she can boot in and do 32m all day long @ like 1.16v but to get her stable she needed this...
http://i207.photobucket.com/albums/b...marks/LOL2.jpg
http://valid.canardpc.com/show_oc.php?id=915657
~Bex
hi everyone i was wondering if i can run 2x 285s in sli but using the 1st and the 3rd pci-e slot mainly becuse if it in the 1st and 2nd there will be to close for my likeing it says in the instructions that the 3rd slot only runs 8x and not 16x so will one of the cards run half the speed
thanks everyone
(this is an upgrade and not sure if i shuld do it by the way)
New bios works great with DVID!
Testing out an older chip that I never got around to:
http://individual.utoronto.ca/bzhou/...w3520-4200.png
Uncore @ 3200
Apogee GTX+PA120.3+Sflex F+DB-1 pump + poor mount!
hi, ive got a small concern here with my UD5..
The power LED on my casing seems to be blinking under normal operation, while the manual says thie led should stay light up.
googled and people have been saying DES might be the reason behind the blinking power LED, but i've not installed any utilities from the cd yet.
bios of my ud5 is F8e, could it be a bios issue?
flash the f9m bios!
http://europe.giga-byte.com/FileList...58-ud5_f9m.exe
