freeza: if you are at 50c idle you may want to consider getting a better cooler or backing your OC down to lower temps. The Ultra 120 Extreme is a very good cooler for Quads.
hello guys
i wish to know does Gigabyte EP45 has any VDroop under heavy load??? (not VDrop)
(i have been suffered from heavy VDroop on EP35 series)
voltage usaully stays the same between idle and full load
could anyone tell me the difference/significance of the different board revisions (1.0, 1.1, 1.6)?
Do you know why the 1.6 uses a different bios?
Aside from featuring the new Smart 6 system management utilities package(and BIOS), this model remains unchanged.
So, i'm at a stable 3.7 GHz (436*8.5) and i'm wondering if my DDR2 800MHz ram will cripple my attempts at reaching 3.8-4.0GHz on this board?
I'm already running it at 872MHz and it seems to operate just fine, but the higher I raise the FSB, the higher the RAM will go, and there's no way to underclock it with this board is there?
Looking at different versions I've noticed PCI-Express X16 is 2 (1x16 or 2x8) Does this mean that if I don't use one on top and use bottom one I still get X16? It's only X8 when in crossfire? What happens when I use bottom one for my GTX260 and use top one for 9600GT, are they still running at X16 or it's X8?
Take off your heatsink and check the thermal paste. The heatsink you link is pretty decent so your idle temps are a bit high.
After lapping the True, my temp actually went up, running Linpack the temp climbed to 90 C. Scratching my head, I took the heatsink out and peeked underneath. Found out by looking at the thermal paste imprint that the Q9550 was not flat, as a matter of fact both sides were raised with an indentation in the middle. After lapping the CPU, my temp were at an all time low. Idling at 36; prime at 60; Linpack at 66 max.
I agree wholeheartedly about lapping both the True and the cpu ihs. REmember, there is a difference between lapping and polishing. GEt both surfaces as flat as possible, then polish if you want. Apply thermal paste sparingly. Insure that you have a good mount with even pressure on all corners. You might want to look into the "washer" mod- I did and it helps. At the settings below I run 38-40 idle with ambient in the mid 80's F, and in the 60c range while gaming. These are not exception, there are average for a properly prepared True.
I am not satisfied with 4300mhz- I want at least 4500 or more. This is definitely going to take liquid cooling.
Follow the suggestions given and you should have no problems at your clock speeds.
I agree wholeheartedly about lapping both the True and the cpu ihs. Remember, there is a difference between lapping and polishing. GEt both surfaces as flat as possible, then polish if you want. Apply thermal paste sparingly. Insure that you have a good mount with even pressure on all corners. You might want to look into the "washer" mod- I did and it helps. At the settings below I run 38-40 idle with ambient in the mid 80's F, and in the 60c range while gaming. These are not exception, there are average for a properly prepared True.
Watching you guys with those Quads makes me want one. But I can't shellout $320 for a Q9650. However, I see that Micro Center has the Q9550 for $169.99, at a high FSB the 8 or 8.5 multiplier is good enough for me. Maybe I'll see if I can sell my E8500 and pick one so I can join the Quad Core Club!!
Nice OC's everyone :clap:
If I'm going 8GB 4x2 on this board, what line is recommended? I want to be stable obviously, and be able to match a relatively high FSB with the ram. Are there any favorites? Does D9 still matter?
so there is no way to adjust the mem to lower freq when OCing the CPU?as the cpu/fsb goes up so does the mem OC??? guess i am headed to a ASUS board. was wanting to get on of the UD3P boards. is the UD3P a 8 phase board or 4?
Yep correct intel's lowest divider is 1:1, to get the most out of P45 you need to run a divider, so let's say with 500FSB , it's preferrable to run 1200mhz on the rams... don't downgrade to a Nvidia board , upgrade ya rams Cincyrob... UD3P phases will handle any quad fine
Posted in the q9650 thread but wanted to post in this one as well. I love this board. Finally getting close to 4.5ghz.
http://img43.imageshack.us/img43/9905/3hours.png
so then i should be looking for bigger ram than 1066?
as for the divider say 5:6 that is what i should be trying to get my ram at now? instead of the 1:1 mark? i dont think my mem now could handle that.
no many ddr2 1200 to choose from. was looking at ddr3. wow the prices have dropped on them,
