nothing if you need help ask :)
LinX
Just a suggestion, rather than setting it to use all system memory, take the max amount it displays and subtract 100mb or so. Or you may start running into virtual memory issues which will make the test not accurate.
It's taking me 1.4vcore to get the CPU stable at 21x with a 191BCLK.
My chip batch is 3836B. Isn't that vcore a bit high?
Also, I have HT On.
my cpu will pass linx 191x21 but fail p95 blend i've tried with vcore up to 1.375 but temps get way to high to try more vcore
Look carefully at the CPU speed with CPU-z or Realtemp while using high stress with the 21x multiplier. Use LinX if possible. You will notice the multi will drop back to 20x, where it is less stable than 21x...
what does the ICH and IOH voltage directly affect?
is there going to be a bios update for the p6t?
that would suck if there's no 21x
Is there any good guide online how i should start to oc?
What settings to enable and disable in the bios etc???
I've got a feser 360 with push-pull config but I'm new to oc'ing :)
Yes I'm currently looking for a TRUE 120, although the Zalman 9700 does great for 3.8 but I want to shoot for 4.0GHz
Any adapters for the Tuniq Tower 120? Will it do better than the hyper N520? It seemd to do a good job on my q9550.
I am looking for a good kit triple channel ram 3x2gb for overclock on this board what do you suggest me?
I think I read somewhere that the Tuniq is not capable of properly cooling an overclocked i7 because it gets so hot that the liquid in the heatpipes evaporates and is unable to properly condense again, which leads to very ineffective cooling. The Thermalright TRUE is supposed to be the best as far as air cooling goes, maybe aside from those two gigantic coolers from Scythe. Keep in mind, this is just what I've heard. I don't have any personal experience here and can't guarantee the accuracy of the information.
This is the stuff to have.
