http://valid.x86-secret.com/show_oc.php?id=238914
WR :)
Niceone, what's the Vcore your using?
1.55 x 1.144 ~ 1.77V.
What cooling?
Congratulations! :yepp:
You should get this into the WR database here on XS.
Nice job, m8.
I'll do my best to beat it once I find someplace that sells that stepping:D
WOW nice chip, I'm hoping mine is the same stepping!!!!
Thank you! :)
@ v0dka
I cooled with water. Was outside on the balkony, because the ambient temp was low (10°C). Will try the same in winter :D
9°C/18°C. but the 9°C is for sure wrong because the water temp was 14°C!
Well, just ordered my Opty 180 from Newegg. I could have sworn in the past you could add a note to the purchase a CPU in which most people would put their request for whatever stepping they wanted. I coudln't find this anywhere and even spoke with a support rep and they informed me I couldn't add a note or request to my order at all. Sucks.
I'm REALLY hoping I get an LCB9E or even better, an LCBQE stepping. Hopefully it will scale similar to Biohead's. I'm going to be pissed if I can't run 3Ghz 24/7 like I can on my 4000+.
New result :)
http://www.abload.de/thumb/3200stable43r.jpg
I doubt they'd have that many you'd have a real choice. The 185 I picked up about 3 weeks ago was a LCB9E if that helps any. It does 3G easy and was able to take a suicide screen at 3.45G. Thats on air. The one comming from the Egg lately seem to be doing pretty good. I'd say you have an excellent chance.
this is how much i need for 3000Mhz.
http://www.abload.de/thumb/3000stablewez.jpg
No it's not 1.28V ;) The multimeter says 1.261V :)
And yes, it is still on water. Don't know, why core0 is so hot. This is how it is right now:
http://www.abload.de/img/_mg_4779-01mpa.jpg
Köszi ;)
Your chip is quite strange:confused:
1.28v (CPUZ) for 3g, and 1.312v for 3.2g. That's nice scaling. And then nothing more? Jeeeez.
I don't know how much the DFI gives wehen CPU-z shows 1.312V. It's 1.35V in BIOS and i think the it has to be ~ 1.346V. Dunno
The 3200 with 1.35V was with 14°C watertemp ... didn't test more, because my girlfriend wanted to watch a movie ^^
But 3300Mhz would have been possible with 1.4V i think ... dunno
Another tests in winter @ -10°C ambient ;)
Hi all,
I've been reading these pages for a while now so I thought I'd register and give you my input :D My stepping is CCBBE 0615EPMW.
http://img258.imageshack.us/img258/9...coreih5.th.jpg
It will go higher (3.05GHz) but I'm only using an AF64 Pro to cool the CPU so I can't really up the volts & I can't get a better cooler due to my case :(
http://img520.imageshack.us/img520/4...5ghzps9.th.jpg
I have a question also, why do some of the socket 939 Optys have different TDPs?
HEY GUYS!!! REALLY EXCITED, MY NEW CHIP CAME IN
LCBQE 0722RPBW
It's not an RPAW like Peter Burg's, but we'll see how it clocks, I'm really busy with work right now, but I'll be sure to report back and let you guys know how it does.
