wow the ep45-ud3p clocks real well, and to think I just sold mine for another board because I thought it would be better for quad..
Nice to see :up:
Hereīs mine EPT45 Q9650 @ 512 ~4,6GHz with 2x2 ram @ 1638 777 21 tRD 9.
3DMark06 are pretty close, you got better VGA points due to higher core clock but I got higher CPU score probably due to better bandwidth and latency from my ram.
Do you run ram @ 1000 CAS5 and with which tRD?
Screenie of bandwidth and latency maybe?
We see the similary tendency with 3DMark Vantage as with the 3DMark06.
It seems like I lose points when I run 3DMark06 with Win 7 64bit compare to XP 32bit with ~1500 points.
http://i282.photobucket.com/albums/k...2TtRD9Tu-1.jpg
http://i282.photobucket.com/albums/k...TtRD9Turbo.jpg
here's mine :D
http://img366.imageshack.us/img366/9...vgaoc1xp32.jpg
Cheers :up:
Sergio
You show off :p
Sergio, it you dont mind rerun that setup under win7, curious to see the difference from xp to 7201.
That is not fair :rofl:
I can boot @ 4.75Ghz but it is only 1M Super PI stable.
I have to put 1.55V to the CPU though. Not sure if it is good for the CPU.My temps all stay below 68 though.
I am running 8 Gigs of ram at 1:1 with 5-5-5-15 pl 9.
I know my ram is holding my oc back. My Bandwidth are between 9200 - 9300 with latency of 58 or so.
When i try go higher i will SS a everst benchmark.
So my slightly higher card gets balanced by your higher memory bandwidth. COOL
These EP45 are some awesome boards, FSB 500+ with a quad, 8Gb ram and tight tRD :cool:
You got a pretty nice chip there, Sergio and my GTX 285 is on air but maybe I can push it some but not much so itīs hard to keep up with you. :D
I think itīs interesting to compare the DDR2 vs DDR3 of those EP45 board.
Iīll try to get a 3DMark06 in XP at the same FSB, clock speed and try to get my VGA up to yours VGA clock, if I canīt reach your VGA clock speed could you consider to lower yours to my clock and rerun your 3DMark06 in XP.
Should be nice to compare that with only the ram speed as a different. :yepp:
BTW, sure itīs a show off but itīs a nice one. :)
Does anyone know if these two sets of Ram the same other than the hs?
http://www.newegg.com/Product/Produc...82E16820227455
http://www.newegg.com/Product/Produc...82E16820227458
Here it is. I have tweaked the ram slightly
http://i40.tinypic.com/2jfyx03.jpg
Hoss31 this is the same run on Win7 7201x64 hughe difference...i just gave a notch of vcore and MCH as i did the other run on XP32 wich needs less volts
when i run 3DM06 Win7 disables color scheme and goes to basic...
this is at 4608/1229 my actual 24/7 with 1,408 vcore
http://img40.imageshack.us/img40/926...293m06run2.jpg
this is at 4635/1236 just a test with 1,42 vcore
http://img40.imageshack.us/img40/502...363m06run1.jpg
Cheers :up:
Sergio
There definitely nice sticks and most seem to oc well. The 1200s were only instock at the egg for maybe 2 days, I was checking availability daily to make sure I got a set when they first popped up. I played with mine a little today and got them to 1300, not stable though.
http://i131.photobucket.com/albums/p...tmapImageu.jpg
just installed nvidia 186.08 drivers (i removed on safe mode 185.85) and all benches give me lower points :mad:
http://img197.imageshack.us/img197/9564/capturatic.jpg
