If it's fake it's the most accurate one to date ;)
I'd say Intel's design works in a "brute force" way, just pouring tons of resources into it.
Whereas AMD relies on being clever and more efficient with the resources they have.
Having the modules design allows more cores per die area.
Didn't someone say 8 core BD was about 1% larger than 4 core SB?
Which would mean Intel is forced to compete on a smaller node.
AMD is REALLY holding it all back. No leaks at all.
Check out this totally legitimate screenshot:
https://sites.google.com/site/apokalipse/Norrissor.png
Chuck Norris was nice enough to design it himself
hehe, n1 :D
is that the one from back in january-ish?
if i remember that right, if we just add cores + cache it came to like 250-275mm2, but its really going to be like 325mm2+
We discussed that on the last page, that it's fake. :\
(still in response to Flanker) Like I mentioned, creating that isn't hard, I'll go ahead and finish mine just to show that point. That's probably why they blocked over the L3 and version part, was more an amature job. Not that it was bad (or that I'm not an amature), but what sells it is how they went about presenting it!
AMD did it before, with the K7 and then again with the K8, beating Intel with more design thought vs the 'brute force' or 'pure horse power' method. I think P4 is a great example of that. Anyways, I think it is definitely time for AMD to shine again, and will be more impressive (and a good "gotcha!") if they achieve more performance with the smaller die size :) (OK, not 'die size', but per-core size)
I think Intel's biggest 'oops' with designing was actually ditching the development of their improved graphics core :shakes: Their current GPUs are obviously a lot better than their past iterations, but it's quite lacking compared to the AMD approach. The E350 might only have an HD5450 (if not completely, damn near), which performance-wise fits amazingly well with the E350, so I'm expecting Llano to really put the hurt on the i3; maybe even i5!
yes, but it was repost again as image....So we talking again about it :)
haha Yea, it's been awhile that's for sure. I'm honestly curious as to how much is original and how much has essentially been scrapped in favor of new architecture (though not necessarily from the ground up)... Would be quite interesting.
Well, ya learn something new everyday lol
Anyone know why Llano is being designated "12", when 'Dozer and Bobcat are 15 and 14, respectfully?
why not? Llano is not K10 and not is K15...
I've wanted to contribute to this thread since I started reading, but had nothing to add. Hope this is as intriguing/comforting to others at it was to me:
AMD release schedule
9 series chipset is due out on June first then. About time :)
There's a Fudzilla article today, . I don't think I'm going out too far on a limb by saying...
990FXA-GD80 and 990FXA-GD65 are the same chipset, the 990FX and have the same number of PCIe lanes available on the chipset, so the 4 x x16 slots on the first board will be x8/x8/x8/x8 or some combo, and the second board will be x16/x16. That means little or no difference from the config of motherboards that we have now. Although perhaps they'll try to distance the x16 slots a bit more to accomodate triple width cards which are becoming more popular.
I don't think we'll learn much from distributors listings of the boards etc until reviewers get the boards with CPUs as it looks like much of the chipset features will be power management related?
I'd imagine it would be very similar to the current AM3 GD70 and GD65, so just a few options swapped out, but largely the similar.
Leaked slides via Techreport:
http://techreport.com/discussions.x/20886
Original site translated via Google:
http://translate.google.com/translat...-sonuclari.htm
Well, some things definitely stick out, like the 2nd image showing under BD/FX: DX11 and Eyefinity. Thoughts? I mean, unless they're packaging a 6670 with every Zambezi chip sold, do the 3dmark scores hold? Bizarre to see.
