Thanks for the informative post Clint. Hopefully I'll have some time tomorrow to do some thorough testing.
pls advice in laymans terms how to do this... Im still a newbie to this.Quote:
3b. In XP add "/noexecute=alwaysoff" to your boot.ini (without ")
Thank you
would you advice the P5K3-Deluxe over the P5K-Deluxe? because i dont want to upgrade my motherboard in the next two years (when DDR3 becomes cheap).
As shown here http://www.nextsymbian.com/forums/vi...9b50aa64e512fd
Disable DEP / NoExecute Protection
DEP, otherwise known as NoExecute, is a piece of technology in Windows that prevents processes from being altered in live memory. This lowers the frequency of certain attacks, but it can also have some adverse effects and cause certain things not to run.
Due to the way Windows Vista™’s boot editor has been created, it is now harder to disable DEP / No Execute Protection. Here's how to do it:
1. Click Start, All Programs, Accessories, right click on “Command Prompt”, and click “Run as administrator”.
2. If asked for permission to run Windows Command Processor, click on Allow.
3. At the command prompt, type in “bcdedit.exe /set {current} nx AlwaysOff” (without the quotes).
4. You should receive a message saying “Operation Completed Successfully”.
5. Restart the computer, DEP / No Execute should now be disabled.
If you want to disable it in XP you will have to edit your boot.ini you'll find in root of your systemdrive
It looks like this:
ChangeCode:[boot loader]
timeout = 30
default = multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS = "Microsoft Windows XP Professional" /noexecute=optin /fastdetect
/noexecute=optin
to
/noexecute= alwaysoff
Now, if you have installed the dual core fix then you will have another switch there that we need to adjust for:
Make sure you'll have the switches in this order.
/noexecute=alwaysoff /usepmtimer
My boot.ini looks like this: (XP and 2003 uses the same switches)
:up:Code:[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows Server 2003, Enterprise" /fastdetect /noexecute=alwaysoff /usepmtimer
XtremeTiramisu
So all this temp loving is from only lapping your TR120U EX and not also your Q6600?
6 hours lapping, don't your arms, hands and body hurt after that? :)
1. Go to your C: directory (or whatever your main OS HDD is on)
2. Tools, Folder Options, View tab
3. Select the dot box for "Show hidden files and folders"
4. Scroll down a little and uncheck "Hide protected operating system files"
5. Now the "boot.ini" file should appear in your C: directory
Sorry to be such a bother but its not showing on my computer, thank you pmisley, not inside them folders either.
http://i159.photobucket.com/albums/t...lderView_0.jpg
sorry xtremetiramisu, dont mean to hijack your thread.
I did...Quote:
You have to goto folder options and advanced, and check unhide protected operating system files, and hidden files.
http://img102.imageshack.us/img102/4...optionswt4.jpg
Any positive results so far from making this change and disabling Execute Disable Bit?
RLM
yes, i did, thank you to all. RLM did the trick, now to try it. thank you. again sorry xtremetiramisu... cheers
Yup, works great, tried it in aquamark3, gained 3000 points on that tweak alone. cheers
To Everyone:
You'll see me doing another review similar to this one I've in the next few days
I'll be testing the new P5K-Premium (Black Pearl) and the existing Q6600 G0 + Ballistix Tracers 8500 I've. I'll be including a 4x1GB OC results as well. P5K-Dlx 4x1GB OC results didn't impressive me as much as everything else so I hope the Black Pearl will do better in this area.
this DEP technology was there to protect the cpu and other programs from malicious virues or trojans, right?
SO...i presume if you have a very good virus protector installed, you or i can afford to turn this service off...is that how you see it?
guys do u really think that the temps are right on these new chips, i will post a screenshot of my e6850 oc so far to 3.8 stable. been running prime 95 for 2 hours now. i mean i chip ildes at 20c at 3.8, even on water that is no way right, i mean i would be happy to think thats right, but i am admitting that these temps are not right. at 3.4 i was idling at 10c, coommon now, those are tec temps, not water.
see my system temp, thats probably the temp in my room, may be 2 degrees higher, my portable ac is sitting right next to my computer.
http://img98.imageshack.us/img98/6149/38stableoh5.jpg
fun little chips:
http://valid.x86-secret.com/show_oc.php?id=224147
