Hey, that are some nice results ! You just keep on going :)
Seems that I need to set tRD 2rd and tWR 2wr manually. If I leave it on [ Auto ] the board sets it to tight for PL9
Loosening those settings gives me a lot of stability in return.
http://www.plaatjesupload.nl/bekijk/...279668-810.jpgCode:******Gigabyte EP45 UD3P******
******Channel A and B Timing Settings******
Static tRead Value [ 8 ] ................[ 9 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ 8 ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ 8 ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ 7 ]
tRD 2wr (Same/Difft Rank) [ 7 ] ................[ 9 ]
Only high voltages are vCore and vMCH. Tried 1.48v but LinX wil error. Also tried a noth lower vCore but same thing.
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8.0 ]
Fine CPU Clock Ratio............................[ .5 ]
CPU Frequency 4.465GHz..........................[ 496 x8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 700mv ]
PCI Express Clock Drive.........................[ 700mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Standard]
(G) MCH Frequency Latch.........................[ 500MHz ]
System Memory Multipler.........................[ 2.50A ]
Memory Frequency 1066...........................[ 1250MHz]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 6 ]
tRCD............................................[ 6 ]
tRP.............................................[ 6 ]
tRAS............................................[ 18 ]
******Advanced Timing Control******
tRRD............................................[ 9 ]
tWTR............................................[ 6 ]
tWR.............................................[ 8 ]
tRFC............................................[ 7 ]
tRTP............................................[ 5 ]
Command Rate (cmd)..............................[ 2 ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Disabled]
******Channel A and B Driving Settings******
Drive Strength Profile..........................[ OC-1333 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.25000 ]...................[ 1.46875]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU PLL [ 1.50 ]...................[ 1.570 ]
CPU Reference [ 0.760 ]...................[ 0.785 ]
MCH Core [1.100 ]...................[ 1.500 ]
MCH Reference [0.760 ]...................[ 0.768 ]
MCH/DRAM Refernce [0.900 ]...................[ 0.900 ]
ICH I/O [1.500 ]...................[ 1.500 ]
ICH Core [1.100 ]...................[ 1.100 ]
DRAM Voltage [1.800 ]...................[ 2.140 ]
DRAM Termination [0.900 ]...................[ 0.900 ]
Channel A Ref [0.900 ]...................[ 0.900 ]
Channel B Ref [0.900 ]...................[ 0.900 ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Enabled ]
CPU Enhance Halt (CIE)..........................[ Enabled ]
C2/C2E State Support............................[ Enabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Enabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Enabled ]
