I don't have my board yet so I can't check myself, but does the Component Overheat Protection - EX allow you to shutdown the machine due to temps?
how do you update the bios without a floppy disk or cd ? is there any way ?
Also Status update I got my Maxmius Formula up and running replacing my P5K deluxe and seems to be working ok, but does Anyone know what the OPT_3 temp sensor is for? my system rebooted while priming and the bios came up w/ a msg it overheated, any idea?. I just disabled monitoring for that sensor (it was set at 90C) this is w/ bios 802 as I'm awaiting a final version of 9 before upgrading.
dont have a flash drive :(
Make sure you read this post on how to remove the N/S Bridge heat sinks.
Are you stating, that asside form confirmed in BIOS and matched with Everest core temps, that you actually get a reading higher then reported by any of the other apps?
If you guys are speaking of the temps reflecting the combined core temps, (numbers around 10c higher then previoue CPU die temps) then this is norm since v0701 and is most preffered since this temp is more important then the heat sink die temp.
what settings for 3.6GHZ please ?
Q6600 G0
DDR2 800 Crucial Ballistix 4GB
Tuniq Tower
XPSP2
let me know
Welp seem stable w/ my Old overclock of 3.2 that I had on my P5K Deluxe although I have lower temps
edit: although I'm only currently running 2x1 GB of the balistix as my other set is still on RMA w/ newegg.
what settings did you use for 3.2?
To Warboy and others with RAM voltage spikes:
I remember reading way back from a post on product reviews for maximus se on newegg's site that your PSU would need 30A at 3.3V for this board... Total Watts doesn't necessarily matter. Also I read for improved performance, if you are using 2 sticks of RAM, use the B slots...
if it was the memory, why would there be a huge ripple in the Chipset too? The Other Power Supply is a Apevia, and its really good from what I've used it for.
Where did you read that? Anyways my 3.3 gives off 25A and the 5V is 30A
I'm at work atm so can't post them, but it's a pretty moderate OC and 3.2 is nothing special my chip will run 3ghz if you leave everything on auto and just up the FSB to 333 I'm still trying to dial things in as I have a new cooler, I left it running Prime 95 until i get home :)
I ran a test to compare some information that was posted a page back.
9x400 1.55v ram at 1066 2.2v ( ram in blue slots )
http://i237.photobucket.com/albums/f...-08h54-RAM.png
9x400 1.55v ram at 1066 2.0v ( ram in white slots )
http://i237.photobucket.com/albums/f...-09h43-RAM.png
My 450x8 settings OCCT and Prime stable
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency : 450
FSB Strap to North Bridge : 400MHZ
PCI-E Frequency: 110
DRAM Frequency: DDR2-1199
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
Ai Clock Twister : Strong
Transaction Booster : Disabled
CPU Voltage : 1.55
CPU PLL Voltage : 1.60
North Bridge Voltage : 1.55
DRAM Voltage : 2.20
FSB Termination Voltage : 1.50
South Bridge Voltage : 1.10
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Channel A REF Voltage : DDR2_REF
DDR2 Channel B REF Voltage : DDR2_REF
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Disabled
Advanced CPU Configuration
- Ratio CMOS Setting : 9
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Enabled
Ok, Here is My ram in the blue slots, The slots they have always been in. Here also, Is my Chipset voltages.
http://img126.imageshack.us/img126/9...1memorywh8.jpg
Orange is the chipset, Black is the memory.
As You can see here, When the Memory/Chipset spikes its counter part Memory/Chipset also spikes.
Which is highly abnormal.
Are all 3 pin fan connectors speedfan compatible (barring the PSU fan connector)? I heard that the CPU fan connector couldn't be controlled by Speedfan if a 3 pin fan was in there, only a 4 pin, but that all the other connectors were speedfan compatible. Is this true?
So what is your suggestion to fix this? And making it possible to load windows with a bit higher fsb. It's so wierd, I'm running the computer at 457 * 8 right now and it seems to be stable. And why is it always when the windows is loading that the computer gets stuck. Is the harddrive connected to the fsb in some way?
