Komplett
Hi
At the mo yes.Shes under the Nautilus with a better radiator in (Black Ice Pro)
Although I cant get the lid on as I can't find any 1/4 bpst to 3/8th angled barbs anywhere.
Am now at 2600MHz on 1.3v but have not tested for stability yet.Idle temps are Core 0 24 deg c and Core 1 21 Deg C.
Will report load temps when Dual prime is up and running.
Smiffy
PS
They seem to have changed the design of the oem heatsink a bit.Will try and take some pics.
Once I can get the barbs for the Nautilus that will cool the 1900XTX with a swiftech MCW60
and then the Opteron will be cooled by a D-Tek Fuzion pumped by an Iwaki MD15R via a Black Ice Xtreme 3 radiator.
Smiffy
Load Temps at 2600Mhz on 1.3v Core 0 36 Deg C Core 1 39 Deg C
Smiffy
Not bad Smiffy. Did they change the OEM heatsink for the better or worse? Or at least from your observation?
Hi All
The one on the left.Noticably more fin area and larger but a smaller fan,seems to be 70mm on new against 80mm on old.
Popped it on my Opteron 146 running 3Ghz in the DFI RDX200.
Smiffy
Back again
Testing stability at 2800Mhz still on 1.3v
Been running Prime 95 dual core test 1 hr so far.
http://www.diy-street.com/forum/showthread.php?t=16446
Smiffy
Hi All
Fine at 2.8Ghz.Testing 2.9Ghz on 1.325v
Smiffy
Update on the OC of my Opty 185 -
2880 (240x12) @ 1.40 - Orthos and FAH okay
2940 (245x12) @ 1.40 - Orthos and FAH okay
3000 (250x12) @ 1.45 - Post and CPUz but Orthos failed.
Up to 3GHz but needed a bigger jump on voltage.1.425v
Smiffy
Hi all... I'm a happy owner of a Opteron 165 :)
Rock stable @ 1.35v on a DFI NF4 Ultra-D. I've tried boot at 300 of HTT with 1.425v, but I got a error in a windows vista file (corrupt file).
My results:
9x289 = 2600 @ 1.30v -> Freezed after a while using Folding@Home
9x289 = 2600 @ 1.35v -> Rock Stable with Folding@Home 24/24
9x300 = 2700 @ 1.245v -> corrupt file in windows while booting
Please tell me somethings:
- Do you think I can go a little higher?
- Could it be a problem because I'm using Vista? Maybe with XP Pro I wouldn't have this problem?
Here's the stepping of cpu:
Ups... forgot to leave here that info :rolleyes: and need to correct one thing:
9x300 = 2700 @ 1.425v -> corrupt file in windows while booting
I have a Scythe Ninja heatsink with a SILVERSTONE FM122 120MM fan.
Unfortunately, my currents temps are a little bit high... I need to put some new Artic Ceramic on my cpu.
With cpu fan @ full speed:
Do you think it might be trouble with your RAM? If you are stable at 2.6@1.35, 2.7 should be almost stable with 1.425, if we apply the .1v:100MHz rule that nearly all of these seem to follow. Try 1.45 and maybe play with some dividers and RAM settings
I have 2x1GB G.Skill PC3200ZX and they are already with the 140 divider, which means that they are at their default speed. I'm giving them 2.7vdimm, but my DFI overvolts them at almost 2.8v.
RAM settings? Eish... don't understand anything of that in these boards :( Don't know what to change... too confusing :(
I have the same RAM, try lowering voltage to 2.6 or even 2.5v (the sweet spot for mine). We'll make it easy, post up an A64 tweaker screenshot so we can see if there's any changes that might help you out
@ BRSG:
I also have the same RAM. Please take a look at this thread about the ZX: http://www.xtremesystems.org/forums/...5&page=1&pp=25
It really helped me allot getting the right bios settings :up:
These are my settings:
Code:Genie BIOS Settings:
FSB Bus Frequency............................. - 326
LDT/FSB Frequency Ratio....................... - X3
CPU/FSB Frequency Ratio....................... - X9
PCI eXpress Frequency......................... - 105Mhz
CPU VID StartUp Value......................... - startup
CPU VID Control............................... - 1.400
CPU VID Special Control....................... - 104%
LDT Voltage Control........................... - 1.20v
Chip Set Voltage Control...................... - 1.50v
DRAM Voltage Control.......................... - 2.60v
DRAM Configuration Settings:
DRAM Frequency Set............................ - 166=RAM/FSB:05/06
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - 3
RAS# to CAS# delay (Trcd)..................... - 3
Min RAS# active time (Tras)................... - 5
Row precharge time (Trp)...................... - 2
Row Cycle time (Trc).......................... - 7 Bus Clocks
Row refresh cyc time (Trfc)................... - 13 Bus Clocks
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 01 Bus Clocks
Read to Write delay (Trwt).................... - 03 Bus Clocks
Refresh Period (Tref)......................... - 3684 Cycles
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - Level7
DRAM Data Drive Strength...................... - Level3 (reduce 15%)
Max Async Latency............................. - 8
DRAM Response Time............................ - Normal
Read Preamble Time............................ - 6
IdleCycle Limit............................... - 256 Cycles
Dynamic Counter............................... - Enable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(4 Bursts)
Opteron 175, (toledo) LCB9E 0652 WPMW
1.st boot test Orthos stable 1h+ 2.8GHz @ 1.4V with boxed cooler
Repoman, thx for helping me :)
WoutZoR: I'll check that thread, thx :)
Meanwhile, here's a screenshot of A64 Tweaker (I have everything at auto in bios)
No problem. But, your A64 Tweaker SS is screwed up. Keep hitting "Refresh" at the bottom there until the numbers change to something a lot lower, and until the asterisks go away.. you'll know it's right when "Write CAS latency" is 1, that's the only number that works with DDR memory. A value of 2 or above will make the system not boot, or if set in Windows, freeze immediately
That thread basically gives you good starting numbers though. I was gonna give you numbers that I've found myself to be the best, most are the same as in that thread (a few of mine are a bit tighter).
