WTF ?!?!?!?!
The new version isn't on ASUS site any more!
I really don't know, what is going on ...
P.S. Hehe, the new BIOS is back online. I really hope, this time, we will have an improvement.
Here's a direct link:
2104
I never seen it on Asus site but the FTP.
I have gained nothing with this Bios.
Boot 4 sticks of my ram (Rev 1.1) to 1175mhz with normal voltage and no fancy tweaked settings but CANNOT boot out of Bios to even Post with just 1 stick beyond 1175mhz no matter how much voltage or settings tweaks.
OK..I've tried '2104'..:)
vNB-VTT issue : Present:)
Pull-ins NOT Working:Present:)
A little bit Lower Ram Bandwith at my 1901 27/4 Settings: Present
BSODs At my 24/7 Settings:Present
BIOS 1901
http://www.outofspecs.gr/forum/attac...4&d=1241875017
BIOS 2104
Same Settings All Pull-ins enabled.
http://img13.imageshack.us/img13/975...iosmoderat.jpg
Nice Work.. ASS-SUSİ BIOS Engineers.
It took 5 months to add one more ''OC CPU Level Up'' Entry.:down: (The only change this Bios has).
ASUS=:sick:
Anybody got funky IDE light action during bootup with 2104???
Hi.
These are my settings for e8400. Orthos, Linpcak, OCCT, SuperPI, etc... all tests were OK, but when i start a 3d game (Burnout Pradise, Velvet Assasin, CoH:Tales of Valor) after a few minutes or seconds, freezes like hell.:shrug::shrug::confused::confused:
First i thought it was win7, but it does the same thing under vista. VGA not OC-ed.
Code:Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
Ratio CMOS Setting: 8
FSB Frequency: 500
CPU Clock Skew: 100ps
NB Clock Skew: Normal
FSB Strap to North Bridge: 333MHz
DRAM Frequency: 1002Mhz
DRAM CLK Skew on Channel A1: Normal
DRAM CLK Skew on Channel A2: Normal
DRAM CLK Skew on Channel B1: Normal
DRAM CLK Skew on Channel B2: Normal
DRAM Timing Control: Auto
1st Info: 5-5-5-16-3-42-6-3
2nd Info: 8-3-5-4-6-4-6
3rd Info: 14-5-1-5-5
DRAM Static Read Control: Enabled
DRAM Read Training: Enabled
MEM. OC Charger: disabled
Ai Clock Twister: Moderate
Ai Transaction Booster : Manual
Common Performance Level [10]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
PCIE Frequency : 100
CPU Voltage: 1.3875
CPU PLL Voltage:1.52
FSB Termination Voltage:1.31200
DRAM Voltage: 2.22400
North Bridge Voltage:1.36500
South Bridge 1.5 Voltage: 1.5
South Bridge 1.1 Voltage: 1.1
CPU GTL Reference (0): -40mv
CPU GTL Reference (1): Auto
CPU GTL Reference (2): -40mv
CPU GTL Reference (3): Auto
NB GTL Reference: Auto
DDR2 ChA Reference Voltage: Auto
DDR2 ChB Reference Voltage: Auto
North Bridge DDR Reference: Auto
CPU Configuration:
Ratio CMOS Setting: 9
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Disabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
Load-Line Calibration: Disabled
CPU Spread Spectrum: Disabled
:up:
OC From CPU Level Up: Crazy
FSB Frequency: 470
CPU Clock Skew: Auto
NB Clock Skew: Auto
DRAM Frequency: 1129Mhz
DRAM CLK Skew on Channel A1: Auto
DRAM CLK Skew on Channel A2: Auto
DRAM CLK Skew on Channel B1: Auto
DRAM CLK Skew on Channel B2: Auto
DRAM Static Read Control:Disabled
DRAM Read Training: Disabled
MEM. OC Charger:Enabled
Common Performance Level [8]
CPU Voltage: 1.25
CPU PLL Voltage:1.56
FSB Termination Voltage:1.20
DRAM Voltage: 2.05
North Bridge Voltage:1.335
South Bridge 1.5 Voltage: 1.52
South Bridge 1.1 Voltage: 1.12
CPU GTL Reference (0): Auto
CPU GTL Reference (2): Auto
CPU Configuration:
CPU TM Function: Disabled
Load-Line Calibration: Enabled
Lol !! Just clocked wit it yesterday morning and it was great for suxx yeahhh !! MFAsus Bios !!!! Don't have any screenies cus' I thin that's useless after all ^^
What I can say is that the NB is limited to 1,54v, the vCore to 1,6v bios (1,58 real loadline cal on) didn't get higher than 440FSB on my E7500 and @4,2 stable -_-
For my Crucials (D9GMH) looked quickely with 3:5 and instead of 1200 it was 1333 :/ don't understand anything ...I'm still furious bout this release !!! Go to H(s)ell MF MIIF !!!
I think I'll go back to 1307 which gaves me more satisfaction.
All my Asus boards have some worth perfs at every new bios rev. so they definitly lost a costumer !!
Yeah, I never bothered flashing to the 2104 BIOS. Even if it were to be the "Bee's knees" of BIOS's, I'm pretty much done with this board and Asus in general.
My interest as of late has been the DX48BT2 and 2 x's 2GB of G. Skill Pi Black DDR3 1600. I've never owned an intel board before so it should prove to be an interesting distraction until I upgrade CPU's sometime 1st quarter of 2010.
Hey guys, anybody got any suggestionos on gettin my 9450 stable?? Here are current settings..
Vcore- 1.5
DDR 2.17
CPUPLL 1.6
NB 1.59
VTTCPU 1.49
Running at 498fsb/1195 mem, PL10, AI-Moderate
CPU skew -200
NB skew -100
GTL's auto (please help here, i HATE math)
Chip and mem are known to run 4.0/1200 no issues....
Any help is appreciated...:cool:
Hello
I have had 4gb ram for ages now and my system has run fine with 450fsb on my Q9450@3600mhz. But recently I ordered more ram, so I now have 8gb and now I cant even get it stable in windows anymore with same settings. I have 4x 2gb Dominator PC8500 ram moduls one par is rev 1.1 and the other is 1.2 if that makes a diffrence. I have tried alot of settings on the ram now with alot of diffrent timings but it dosent get stable at all. Do u have any tips?, I have read the dominator thread on extreme bandwith section and they have 8gb of ram stable on alot better timings then I have. What am I doing wrong? I will post bios settings that works for my 4gb setting:
FSB Frequency: 450
NB Clock Skew: Auto
DRAM Frequency: 1081Mhz
DRAM CLK Skew on Channel A1: +300
DRAM CLK Skew on Channel A2: +300
DRAM CLK Skew on Channel B1: +300
DRAM CLK Skew on Channel B2: +300
DRAM Timing Control Manual
CAS# Latency 5
DRAM RAS# to CAS# Delay 5
DRAM RAS# Precharge 5
DRAM RAS# Active to Precha 15
RAS# to RAS# Delay 3
Row Refresh Cycle Time 55
Write Recovery Time 6
Read to Precharge Time 3
READ to WRITE Delay(S/D) Auto
Write to Read Delay(S) Auto
WRITE to READ Delay(D) Auto
READ to READ Delay(S) Auto
READ to READ Delay(D) Auto
WRITE to WRITE Delay(S) Auto
WRITE to WRITE Delay(D) Auto
WRITE to PRE Delay Auto
READ to PRE Delay Auto
PRE to PRE Delay Auto
ALL PRE to ACT Delay Auto
ALL PRE to REF Delay Auto
MEM. OC Charger: Enabled
PCIE Frequency : 101
CPU Voltage: 1.23750v
CPU PLL Voltage:1.50v
FSB Termination Voltage:1.27v
DRAM Voltage: 2.19v
North Bridge Voltage: 1.44v
South Bridge 1.5 Voltage: 1.50
South Bridge 1.1 Voltage: 1.10
CPU GTL Reference (0): +20mv
CPU GTL Reference (1): +20mv
CPU GTL Reference (2): +20mv
CPU GTL Reference (3): +20mv
That has worked for over 1 year 100% stable with 2x2gb modules, now what should I do to get 4x2gb stable? is it impossible?
Here is the memory thread btw the first postar has the same mobo as I have and only diffrent cpu and his memory runs fine on alot higher fsb and tighther timings:
http://www.xtremesystems.org/forums/...d.php?t=179555
and note I am still using bios 1307 is that my problem?
I think I tried all those solutions with any luck this just sucks:/
Edit: oh wait when I was about to decide it was time to bring the rams back to the store a they started getting more stable :D, But I do run tref @ 105 now lol, 1 hour prime 95 blend stable atleast so far
So none has any ideas?
I'm having the same issues man, i also posted in the GTL settings thread, maybe you should also??
Man, having issues getting the skews straightend out i do believe. I cannot for the life of me get it stable at 1199-99.. Same setup did it on my Formula, but there is better bandwidth on the P45. Only thing is, i havent ran this board in almost a year, and have forgotten bios settings ect... I posted all my settings on the GTL post, think ya could look it over, and give me a heads up???
8GB Ram Timing
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 18 (change to 15 once everything is stable)
RAS# to RAS# Delay : 5(3-5)
Row Refresh Cycle Time: 60(55-60)
Write Recovery Time: 6(5-6)
Read to Precharge Time: 5(2-4)
READ to WRITE Delay (S/D): 12(7-10)
Write to Read Delay (S): 5(3-4)
WRITE to READ Delay (D): 5(4-5)
READ to READ Delay (S): 6(4-6)
READ to READ Delay (D): 6
WRITE to WRITE Delay (S): 5(4-5)
WRITE to WRITE Delay (D): 6(4-6)
WRITE to PRE Delay:14(13-14)
READ to PRE Delay: 6
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 6
ALL PRE to REF Delay: 6
Your GTL's work out to -47.68
so start at -45 and work to -50
CPU GTL Reference 0 : Auto
CPU GTL Reference 1 : -45mv
CPU GTL Reference 2 : Auto
CPU GTL Reference 3 : -45mv
Dram Clock Skew will help to settle your ram down, just play with one setting at a time
Should i adjust the NB GTL also???
WOOT!! The above settings seem to be workin fine so far! Seems i had the GTL's reversed.... Ugh..... Thank's for the new direction!
You ever get those mosfet blocks yet Grn???
