But don't forget. RV870 has had the ROPs and TMUs doubled to 32 and 80, respectively.
GT200 already has 32 ROPs and 80 TMUs. GT300 will have 48 ROPs and 128 TMUs, and have SPs increased by 2.13x, and have SP efficiency increase in the process.
No, nvidia has already stated there will be. It most likely will be dual PCB. There's nothing wrong with that, the 7950GX2 and the original GTX295 were both dual PCB as well.
If power is an issue (which it shouldn't be), there is always the possibility of having three power connectors rather than two, or slightly scaling down the chip, as with the GTX295.
however the 7950 and GTX 275 have far lower power usage than the GF100 to begin with, the GF100 in Tesla form uses at least 225w, so in GTX form it's going to be 250w+, then double that amount, take into account the energy usage of PCB, and we're talking 450w+, so triple 8 pin, and then take into account the heat, the cooler will be huge, and could be triple slot or even longer than the 5870 X2.
I'm not sure anybody with a good head on their shoulders would submit to your logic. Up until the point you mentioned texture and pixel fillrates, you were spot on, and then...I don't know what happened. All that talk about core configurations and average game performance not being indicative of an overall performance picture, and then you go and compare fillrates? Like this is still the DX7 and 8 era?
If fillrates were such an important factor, the 6800 Ultra wouldn't have kept up as well as it did, the 7900GTX should have done at least as well as the X1900XTX (if not better), and the 8800GTX would never have hit the 60%+ improvement over the 2900XT that it often did.
Forget the fillrates, go back to what you were saying about games and drivers and different core configurations. There's too many factors to look at to really even speculate what the performance would be, but the best guesses are the ones that barely even touch fillrates.
nvidia said there will be a dual gt300, but they never said when...
it took quite some time until the gtx295 came out...
ati has been the fastest to push dual gpu cards to the market with a new gen gpu, and even they need a few months for that every time...
so definately dont expect a dual gt300 card anytime close to when single gt300 comes out, which isnt exactly soon either...
What's the point? You can't compare processing units of different architectures that way. RV770 had 800 stream processors and GT200 had 240, and RV770 had not 3.3x the computing processing power of GT200. That's because differences in the way they work.
Yeah, GT200 already has they number of TMUs and ROPs of Evergreen, but RV770 already had more SPs than what Fermi is going to have. So... so nothing because these comparisons are useless.
You can compare with other things of same/similar architecture to try to predict the evolution (of course, assuming that even without per unit and per clock changes, the prediction may fail because bottlenecks, more/less eficient balancing of units, and so, and then may be architectural changes) but comparing units of G80 derivatives with R600 derivatives is kind of losing time.
Until you actually figure it out.I went old school and drew it out on graph paper.(The guys with CAD can confirm this.)
With ATI Cypress at 334mm^2(18.2mmx18.2mm plus .8mm border for cutting(19mmx 19mm)) I get 164 canidates per wafer (41 per quarter).
I took Nvidia's smallest estimated measurement floating around the web at 467 mm^2 (21.4mmx21.4.mm plus .6mm for border cuttting(22mmx22mm))30 per quarter . I get 120 canidate per wafer .
Now even with 10% defect rate added only to ATI you still get 148 ATI to Nvidia's prefect 120 canidates per wafer.The number of gets smaller over 22mm x 22mm
So ATI's faulty yield is 23% greater than Nvidia's perfect yield.
I have no doubt Fermi is an awesome card.
This may work for Tesla at $2000 a pop vs Firestream, but Geforce380GTX against Radeon 5870 the math for Nvidia's partners isn't so good.
It'll come down to profit margins if Fermi will survives.
Basicilly if you make Telsa cards you will be okay, selling GeForce will squeeze margins too tight.
My question is what does BFG,eVGA,XFX and Zotec think Fermi will do for their profit margins.
Nvidia's partners may have the world most powerful GPGPU lying at their feet, but if the partners can't profit from it,well?.
That was an example of smallest Nvidia prefect yield against ATI imprefect scenario
The real question is if Nvidia's partners will profit from this beast.
I think Fermi to Geforce will hurt somebody's profit margin.
At least talking about supporting technologies and so (the new C/C++ compiled code support, for example). Regarding computing power, I don't have it so clear.
The only example that I have been able to find comparing GPGPU performance in equality of conditions (that includes both running the same code, so it has to be a DirectCompute or OpenCL piece), the HD5870 is pulverizing the GTX285.
And the funniest part is that said example, is an NVIDIA demo of DirectCompute (run on both cards in AnandTech). :D
To be exact, this one:
http://images.anandtech.com/graphs/r...2344/20136.png
But yes, I'm of the opinion that NVIDIA is one generation ahead when talking about GPGPUs technologies. We will see in terms of GPGPU performance when we have something else than this little demo to compare. I think it's a too specific program to make any conclusion from this.
A little bit of info on the 3 cards planned to be released (eventually): http://www.fudzilla.com/content/view/15795/1/
The biggest difference between ATI and NVIDIA, the way I see it at least, is that ATI is basing his cards on "logic" sp's, which means that if you are able to make and awesome driver, you get and awesome performance, but if you don't...well, you stick with your reals sp's (160 in RV770, 5 ways each so theorically this makes 800sp's). On the other hand, NVIDIA is not that reliant on drivers as their arquitecture is more "beasty": no logical sp's means that you can improve a few algorythms but that's all...
So, ATI has a long way in order to make the RV870 as efficient as RV770. The only way we are seeing that poor scaling is because of that, they have to improve how the sp's work (in order to keep all of them feeded) and how to manage the new AF which is awesome but is showing as a HUGE problem (compared to older gpus in which AF has been nearly free).
That could also explain why there isn't more difference between 5870 and 5850: the more SP's you have, the more you have to work on a driver so we could say that 5870 is gonna get a lot better than 5850 will (and 5850 is already and awesome product nontheless). Within 6 months time I expect 5870 to totally kill 4870X2 performance wise in ALL games/benchmarks.
The problem is that PCI-E standard allows a card to use up to 300 W of power. Adding more power connectors won't help. If the card uses more than 300 W in PCI-SIG's internal testing(which is done for every PCI-E product, they don't use furmark :D), it won't be PCI-E certified and thus can not be sold as PCI-E product.
MFRs just need to get a little sneaky is all
Bring back the Turbo button :D Just like getting a Hotrod through Emissions...PCI-SIG test passes then a little softmod (read: Nitrous) and [Voice="Billy Mays"]Ka-Boom![/Voice]
Growing rift between desktop and GPU...
can somebody from industry explain how they're able to scale graphics memory so high, especially GDDR5.
desktop
DDRAM 266-400
DDR2 533-1066
DDR3 1066-2000
mem cell clock rate improving marginally, especially recently - 200, 266, 250Mhz
GPU world
GDDR 400-750
GDDR3 800-2200
GDDR5 3600-5500
mem cell clock rate 400, 550, 687Mhz??
Furthermore, speeds of GDDR3 doubled from ~1000 for 6800/X800 in '04 to 2200 for 9800GTX 5 years later.
4870 launched just recently with 3600. 5870 already uses 5000. And Samsung 7000 chips already entering production: 224GB/s 256bit, up to 336GB/s 384bit for GT300!
THATS CRAZY REMARKABLE PROGRESS IN 5 SHORT YEARS SINCE 6800 LAUNCH.
Maybe AMD should start using GDDR3 or GDDR5 for desktop. With a couple PC3-1600 DIMM, you only get 25.6GB/s. 5870's GDDR5 would give you 80GB/s - 3x more.
I dunno what to think anymore. Its way far more complex nowadays then back in TNT2 or Geforce1 days. AMD almost certainly using different code paths for R7 and R8 since architecture improvements.
* For all we know, there could be hardware issues that impact shader efficiency (newer doesnt always mean better).
Ofcourse, all R7 optimizations might not apply or haven't been added.
* HQ AF could also be killing performance - who knows - its always on, so you cant test without to see impact.
* But, looking back at remarkable driver improvements on GeForce2, how X800 3DMark and BF2 performance climbed over the years, and ofcourse fantastic CF scaling improvements on 4870's - one thing's for sure - 5870 will get better with age.
I never compared DDR to GDDR directly. I was highlighting the percentage differences between generations. Just look at the ratios. Scaling of desktop RAM seems to have hit a "266" wall.
200 (nForce2 DDR400) -> 266 (Typical highend Core2 DDR2-1066) -> 250 (i7 DDR3-2000) is a modest mem cell clock rate improvement on desktop
375 (9800XT GDDR) -> 550 (9800GTX GDDR3) -> 687 (5.5Ghz GDDR5). That's 47% and 25% improvements so far... 7Ghz GDDR5 will make it 59% faster than GDDR3.
Look at this way.
9700pro was first 256bit card, with earth shattering 20GB/s.
Fastest most expensive X800XTPE had 38GB/s with GDDR3.
4 years later, April 08, 9800GTX is pushing 70GB/s still with GDDR3.
Remarkably, a few months later, June08, 4870 brings 110GB/s, and about a year later, 5870 takes it up a notch to 150GB/s.
Yet, these are all 256bit. It took many many years to go from 20 to 70. But in a a little over a year we're already at 150. GDDR5 rocks! See what I'm saying.
[And I'm not even considering the incredible progress of going to 384, 512 or even 1024 bit memory]
I think it would be funny if NVIDIA shipped A1 silicon to get this thing out on the market by Christmas.
So, a full version of the chip, a harvested version of the chip, and a dual card. Let's say: GTX380, GTX360, and GTX395? I think that's much clearer to make an idea comparing to the GT200 chip, and they will probably be the final comercial names of the three products.
I didn't expect otherwise, sincerelly. The only difference against previous generation launch would be the dual card, but it is a predictable thing since they are going to be late to the market this time. By the time of the launch, ATi will be already selling their X2 card, so they couldn't leave it for much longer.
