Grnfinger, long time no see
Been busy and now ready to get back to work on this overclocking.
E8400 running stable 24/7 @ 3.6ghz, but still need to tune some others off of auto.
Heres my current settings and temps:
Ai Overclock Tuner Manual
OC From CPU Level Up Auto
Ratio CMOS Setting 9.0
FSB Frequency 400
CPU Clock Skew Normal
NB Clock Skew Normal
FSB Strap to North Bridge 333
DRAM Frequency DDR2-961MHz
DRAM CLK Skew on Channel A1 Auto
DRAM CLK Skew on Channel A2 Auto
DRAM CLK Skew on Channel B1 Auto
DRAM CLK Skew on Channel B2 Auto
DRAM Timing Control Manual
CAS# Latency 5
DRAM RAS# to CAS# Delay 5
DRAM RAS# Precharge 5
DRAM RAS# Active to Precha 15
RAS# to RAS# Delay 3
Row Refresh Cycle Time 55
Write Recovery Time 6
Read to Precharge Time 3
READ to WRITE Delay(S/D) 8
Write to Read Delay(S) 3
WRITE to READ Delay(D) 5
READ to READ Delay(S) 4
READ to READ Delay(D) 6
WRITE to WRITE Delay(S) 4
WRITE to WRITE Delay(D) 6
WRITE to PRE Delay 14
READ to PRE Delay 5
PRE to PRE Delay 1
ALL PRE to ACT Delay 5
ALL PRE to REF Delay 5
DRAM Static Read Control Enabled
DRAM Read Training Disabled
MEM. OC Charger Manual
Ai Clock Twister Stronger
Ai Transaction Booster Manual
Pull-in of CHA 1 Disabled
Pull-in of CHA 2 Disabled
Pull-in of CHA 3 Disabled
Pull-in of CHA 4 Disabled
Pull-in of CHB 1 Disabled
Pull-in of CHB 2 Disabled
Pull-in of CHB 3 Disabled
Pull-in of CHB 4 Disabled
Common Performance 8
PCIE Frequency 101
CPU Voltage 1.275
CPU PLL Voltage 1.553
FSB Termination Voltage 1.312
DRAM Voltage 2.10475
North Bridge Voltage 1.45775
South Bridge 1.5 Voltage 1.5
South Bridge 1.1 Voltage 1.1
CPU GTL Reference(0) Auto
CPU GTL Reference(1) -40mv
CPU GTL Reference(2) Auto
CPU GTL Reference(3) -40mv
NB GTL Reference -60mv
DDR2 ChA Reference Voltage Auto
DDR2 ChB Reference Voltage Auto
North Bridge DDR Reference Auto
Load-Line Calibration Enabled
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
Tempertures: Idle/ Load
Motherboard: 38/44
CPU: 27/51
CPU Core 1: 32/56
CPU Core 2: 32/56
Northbridge: 49/56
Southbridge: 44/48
GPU: 38/38
Hope to get this board running even better. As this summer I will be moving on to the i7.
Do you have any suggestions on a Mobo for the i7?
